OK so I don't get the expected low washer/oil warnings so why the hell do I get a warning every time the temp changes by .5c do I get a full screen warning of a slippery road??????? Lovely picture BTW!!!!
What is the actual temp when you get the Slippery Road warning? It should come on when the temp drops to 3 degrees![]()
Ha I wishAny change below 3 degrees seems to set it off:0 Example, I'm driving at a shown 2.0, fine until temp goes to 2.5, then get full screen Slippery Conditions -- Press OK. ****** annoying when it won't even how me when washer bottle is low;0
Not sure there mate. You should get a Slippery Surface warning once, as soon as the temp drops to 3, then not again, until the next engine start. If the temp is at or below 3 when you turn on the engine, you will get the warning then, and not again until it is restarted.
Maybe a Tech 2 session is needed to reprogram? Unless someone else can come along with a bit more knowledge than myself, in this area?![]()
With the tech2, the ice warning can be turned off or on, but not modified unfortunately.
