Results 1 to 10 of 14
Thread: Intermittent vibration/buzzing ... HELP...
    Bedale
    Unhappy Intermittent vibration/buzzing ... HELP...
    Hi
    i have just bought my 1st vauxhall which is a signum 2.0 d elite and loving the car , the problem i have is when i get to 60 and over the front passengers wheel starts vibrating/humming which u can feel through the whole car but its not constant its more intermittent . Thinking it was the wheel as it does have sum damage on the alloy but nothing major ive swapped front to back but still the same , thought it might be brake disc warped but cold to the touch when been for a drive plus no vibration coming through the pedal when braking , so im thinking the bearing but thought it would hum constant rather than intermittent plus it doesnt make any difference when cornering .... Any help please
    many thanks
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    jack it up see if you have any play grab top and bottom and pull and push but sounds like you have diagnosed it right wheel bearing
    Regular Member mase56's Avatar
    oldham
    Sounds like the tyre needs balancing, can you see the lead weights on the wheel, it could be a bearing but you will usually hear a clunking if the bearing has colapsed
    Bedale
    Hi mase56
    ye checked the tyres and swapped them over but made no difference
    Bedale
    Hi mark
    thought it would be the bearing to start with but with it humming intermittent and not constant i thought it might be something else and still none the wiser why its vibrating
    oldham
    maybe it could be the bearing, with the weather being bad recently alot of people have been sliding into kurbs ect ect, you should check what markj23 posted that where i would start,
    Aug 2010
    Luton
    road camber makes a difference on bearings and noise if the grab the wheel does not work try jacking it up put it on an axle stand and put it in gear and give it a few revs with the clutch out the diff will only let the wheel in the air spin and get some one to listen
    Bedale
    took the car in to my local garage for him to have a quick look today , he jacked it up and let it run and said it wasn't the bearing and will need to book it in for a proper look so now im completely stuck on what it could be , was going to do the work myself as skint at mo but will prob have to get the garage to do it which will cost me a small fortune probs
    anyone have anymore ideas ???
    Feb 2011
    bedfordshire
    This sounds similar to my problem. I am going to do a few checks on my car this weekend but did you find what the problem was with yours in the end?
    Aug 2010
    Leeds
    Quote Originally Posted by tony_b View Post
    There lass had her vibrator on.
  1. Vibration and intermittent ABS Fault?
    By Chunklamb in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 12:49
  2. Intermittent vibration through the car
    By Celes in forum Y & Z30DT Specific
    Last Post: 3rd April 2012, 10:12
  3. Intermittent Vibration
    By Kev Brown in forum Engine & Drivetrain
    Last Post: 3rd July 2011, 10:31
  4. Intermittent Vibration
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2010, 12:18
  5. Philips 2006 Intermittent Lockups & Buzzing
    By malhudson in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2006, 09:48
