Thread: 2.2 direct very noisey top end
    Wigan
    Unhappy 2.2 direct very noisey top end
    Hello Newb here looking for a bit of advice...
    I've got a 54plate vec c 2.2 direct with a very noisey top end rattle (sounds almost like a deisel ), it's done 87k but has had all new timing/balance chains sprockets etc by local stealer at 76k 18 months ago when i bought it (after noticing a slight rattle). the noise i have now is much worse than the usual tappets in the morning noise. the noise sounds like it's coming from around the top cyl1 / timing area and goes a little quieter with higher revs. is there any easyish checks i can do my self before having to take my wallet out and getting spanked for the privilege at the stealers. Thanks.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Sounds like the chain again mate i'm afraid.
    Regular Member mase56's Avatar
    oldham
    does the come from the left hand side of the engine next to the air box, if so timing chain defo
    Jun 2009
    Middlesex
    Angry
    Had a rattle at the top end (2.2. direct).Turned out to be failure of chain tensioner.Cost me a lot of money to get it sorted.
    Dobs
    Wigan
    how naff are these chains,etc if they only last 18 months !!!!
    any how, decided to take off rocker cover to take a look, doesn't seem to be too much play in chain (3mm ish) unless i press hard down and that pulls the right cam anti clock wise and then you get 10mm play, but am unsure if that's due to the engine actually rotates clockwise. Couldn't get my hand to where the tensioner is to check for play between that and the left cam.
    Essex
    mi-tots - I had my timing chain changed 12 months ago as well as the balancing chain. Guess what I have recently had a similar noise coming from that area, I hope its not it again cost me 800.00 last time. If it is I will never ever buy another Vauxhall!
  1. noisey 1.9 cdti
    By leighhockey in forum Engine & Drivetrain
    Last Post: 14th August 2012, 17:23
  2. noisey 2.2 dti engine
    By peadar in forum Diesel Engine related
    Last Post: 7th July 2011, 19:21
  3. Noisey air con fan
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2011, 08:10
  4. Noisey Pulley
    By neilb1 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2011, 19:55
  5. Noisey Rear End
    By nikroc in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2007, 18:17
