Results 1 to 10 of 13
Thread: Vectra 2.2 sri 16v running poorly
    Regular Member mase56's Avatar
    oldham
    Eek Vectra 2.2 sri 16v running poorly
    Hi all,
    my vectra c 2.2 16v seems to be running quite badly, I thought i heard the timing chain make a horrible rattle the other day but the car has been running like poo before this happened, the car shudders as if im in the wrong gear and does feel a bit under powered whilst driving im thinking maybe the timing is slightly out I maybe wrong, what sort of symptoms will I get if the timing is out thanks
    oldham
    iv been looking at past forums alot say different things lambda sensor, egr valve , coil pack, can cause this engine shuddering symptom, with the cam chain rattling last week im in the dark not sure where to start
    Blantyre
    Has it went to limp mode at all, any codes ?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    If the chain's rattling it's possible the tensioner's gone and it's jumped a tooth.
    oldham
    that was first instinct, it only rattled for about 5 seconds then stopped, will the engine shudder like that if it has jumped a tooth
    oldham
    its not in limp home mode the EML hasnt come on yet
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    As its the SE it's probably not going to be fuel pump related as they don't fail on the SE. But its more than likely to be the chain and in that case you really shouldn't drive it until its sorted. You wont go into limp with a duff chain.
    oldham
    i'v got it booked in thurs for the chain £350 at the specialist i'll get him to check the oil feed port as its prob got the old style oil feed
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by mase56 View Post
    Make sure they are using a genuine Vx chain kit, and that its the new type. The newer oil jet comes in the kit. that doesn't sound like a bad price, the kits alone are about £130.
    oldham
    he did the cim module about 6 weeks ago because the dials failed so thats why its a bit cheaper, ;-)
  1. vectra c 1.8 sri running issues
    By daddycool in forum Vectra C / Signum Troubleshooting
    Last Post: 15th September 2011, 16:42
  2. 2003 Vectra 2.2 Elite -- Very Poorly :( Help !
    By jonnybobs in forum Vectra C / Signum Troubleshooting
    Last Post: 1st August 2011, 17:22
  3. Vectra Running Problems
    By 11mallard in forum Vectra C / Signum Troubleshooting
    Last Post: 7th December 2010, 21:39
  4. Very Poorly Vectra Turbo
    By QuickChick in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 12:25
  5. Poorly vectra
    By Richgb in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2010, 21:31
