Results 1 to 10 of 19
Thread: check battery
    Aug 2010
    york
    Default check battery
    tested battery today,
    12.2v before starting engine
    10.3v start up
    14.2v running
    is this battery ok with it dropping to 10.3v on start up.
    Regular Member gibbon7000's Avatar
    lincs
    All sounds good to me, why do you ask, have you got a problem with something?
    Aug 2010
    york
    Reason i ask still sluggish on start up not smooth it like judders , have checked glowplugs ok,changed glowplug relay.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Try and cycle them a few times if it's a problem. How many miles has your car done? Mine's a bit 'meh' and juddery when it first starts but soon settles down. 200,000 miles on mine.
    Aug 2010
    york
    car only done 75000 , 2003 2.2dti
    Nottinghamshire
    The old battery in my 2.2 DTi showed 12.2 volts. I would start the car, but it didn't sound 'eager' to start when it was turning over. Sometimes it took a bit of time to start and produced white smoke from the exhaust.
    I got 2 battery tests done and both said the old battery was OK. Only the third test at the dealer (£15 if I didn't buy a battery from them, free if I did) said that it needed replacing.
    I got a new battery and it turns over faster and starts quicker with no smoke.
    Jun 2006
    Kirkintilloch, Scotland
    Whilst dependent on the temperature an approximate guide to a batteries state of charge is indicated by the voltage:-
    12.8v fully charged
    12.6v 80% charged
    12.2v 50% charged
    11.8v 20% charged
    11.7v 10% charged
    At 12.2v I would suggest your battery is well on the way out.
    14.2 v is I believe within normal charging range.
    Dave
    Aug 2010
    york
    Car starts first time after a few seconds, but just judders on start up.
    was wondering if i needed to change battery .
    i think it maywell be 7yrs old aswell.
    Nottinghamshire
    Quote Originally Posted by tomo610 View Post
    7 years is good going for a battery. Mine was nearly 8 years old. It won't hurt to get a new one, and you should find the car is quicker to start - less turning over required.
    Aug 2010
    york
    can anyone recommend a good battery for my dti
  1. Alternator/battery check..honda accord
    By nikroc in forum Vectra C / Signum Troubleshooting
    Last Post: 30th September 2012, 09:19
  2. Wheels refurbed, Check - Car Buffed and Polished, Check! !
    By messermitch in forum Quick Photo Album
    Last Post: 18th July 2012, 23:18
  3. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  4. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  5. Flat battery / Check safeguard fault
    By s. buckley in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2011, 20:48
