Thread: Do you live by the phrase "If its not broke dont fix it"
    Nov 2010
    Maidstone
    Default Do you live by the phrase "If its not broke dont fix it"
    Just out of curiosity, been reading up on the 10k boost stuff and wondered if its worth having a blast, theres nothing wrong with the car just wondered if i could some unbefoe seen power. Just dont want something to go wrong by using it.
    There is a fair bit of debate as to these additives and if they do anything at all. I very much doubt it will har manything.
    PRESTON
    I live by the phrase, if it's not broke, don't fix it, but keep an eye on it,,,,sure i have read somewhere that 10k boost can possibly dislodge large lumps of carbon/soot and cause more harm than good,particularly to cars with DPF's. The crud 10k boost dislodges has to go down the exhaust, so if the car is running fine, maybe use a fuel addative to clean injectors etc, something like diesel magic or similar.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    yep live by it as its true
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    big advocate for leave well alone. not an engine flusher type of driver, and no additives. Not even early oil changes for me.
    Particularly don't like changing parts when they aren't faulty - classic example is where many people change the water pump at same time as timing belt, not into that personally - see it as a waste to throw away a good part and it's good to see how long things can last But of course, your mileage may vary - you can do whatever you like with your own car.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I'm unfortunately more of a if it isn't broken, fix it until it is kinda person.
    But yes, I have used 10k Boost and it did seem to make a difference.
    Sep 2010
    in a box
    the water pump one id do as its right there when striped down plus if it went next day or it desides to brake it will smash your engine
    Nov 2010
    Maidstone
    Also been thinking of taking egr off and cleaning as ive read these can clog up, is this wise or only if you have running problems?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by signum_rob View Post
    Does no harm at all to give it a good clean every now and then. A lot of people on here do it as part of a service.
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    Not really - I am planning a pre-emptive strike against the Vec Springs before they snap on me at an inconvenient time.....
    .... like there is a convenient time for a spring to snap!?!
  1. 23th Feb 2013 Rs Tuning R/R "LIVE THREAD"
    By Mark Evison in forum Yorkshire (RO - vacant)
    Last Post: 27th February 2013, 00:09
  2. the one "feature" on your car you couldnt live without
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2009, 13:55
  3. cdti inlet manafold " dont do it "
    By chrisgettings in forum Diesel Engine related
    Last Post: 27th March 2009, 18:26
  4. dont mention the "c" word..
    By bobbyboy in forum General Chat
    Last Post: 13th December 2006, 15:15
what do you mean by if its not broke dont fix it
