Thread: Finally stopped my hids from flashing
    Regular Member i5aces's Avatar
    andover
    Default Finally stopped my hids from flashing
    just thought i would share with you all that i finally stopped my hids from flashing when the car is on but the lights are off,
    i had tried LOADS of combinations of cancellers but none worked,
    asked vx to activate xenon lights to stop the bulb check system and they told me they wouldnt because they wernt factory fit,
    so after a year if driving with the lights on i finally activated xenon lights to present and the dont flash anymore,
    so for anyone else in the same boat it can be done by tech 2 if you find a dealer that will do it or find someone with the proper tools
    Engine : 1.9 CDTi
    I did it with another Tech2 like program aswell
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by i5aces View Post
    WoW, obviously soo busy they can afford to turn away work.
    Nov 2009
    Lancashire
    Is that all it takes then to get HID's to work properly?
    Does it fix the "bulb out" error or just the flickering lights?
    Does this work only with "CanBus compatible" HID kits?
    Sorry for the questions but I've been looking at HID kits recently (headlights are pretty cr@p) but couldn't find a definitive answer. Already got the 'Pop-Corn' tool ;-)
    andover
    grahams,
    as far as im aware it will fix the bulb out warning cant say for sure as i never had it but to my understanding the car wont check them anymore,
    and my kit was "CanBus compatible" but still flashed so in answer to that yes
    only took 5 mins on the "tech 2"
    hids were by far the best thing ever fitted to a vec go for it
    Engine : 1.9 CDTi
    Mine were a cheap £35 set that I had in my old Fiat Punto.
    Changed the setting in the ecu and all is fine.
  1. HIDs finally up and running, wow
    By golfpro in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 22:31
  2. Finally fitted HIDS!
    By davedrinks in forum Styling
    Last Post: 3rd February 2013, 15:58
  3. HIDs finally installed !!!!
    By sinless in forum Electrical & ICE (including SatNav)
    Last Post: 16th July 2012, 22:46
  4. Flashing HIDS
    By paul4400 in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2010, 23:33
  5. HIDs stopped working!
    By andy_hare in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2010, 23:33
