Results 1 to 10 of 15
Thread: no abs or traction control.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default no abs or traction control.
    hi, on my way back from my dodgy wheel balancing session some nugget boy racer pulled right out in front of my, so applied the anchors quite hard and my front wheels locked up, was a dry road. also ive noticed that my car spins alot. thought it was just the wet roads with ice and whatnot. but the roads were in pretty good condition tonight. also when i press my traction control button it does nothing? any help on the guys, cheers, Tim
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    is there any lights on the dash? could be on of the abs sensors on the hubs, just have a look
    Nov 2010
    BRECHIN
    Quote Originally Posted by neill View Post
    nope, no abs lights, traction lights, anything at all. been like this from when i got it. never seen the abs light at all. my old mondeo abs light used to come on with the ignition key for a few seconds then go off. dont know if the vec should be the same? and when i press the traction control button nothing happens either. no light nothing. is it ment to? cheers
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    when you press the tc button you should get a little yellow car with a squigly double line underneath it. if there is no lights or warnings on the dash then you may have to get somebody with diagnostics to do a scan, this will tell you if there is any issues with the abs. You should also check the fuses for the abs and tc, pic below
    check the folowing fuses IN THE ENGINE BAY
    F7 - TCS MULTI FUNCTION CONTROL MODULE
    F13 - ""
    F16 - ABS
    F29 - ABS
    Im not sure if the vec c abs ecu/pump has the same fault that my old vec b had, but the ecu's would fail and the abs, tc would stop working.
    double check all the abs sensors, and if there okay get diagnostics done.
    Hope this helps
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Do you get the ABS light on the dash when you turn the key to position 2?
    Nov 2010
    BRECHIN
    never seen the abs light at all. either thru driving or starting the car. cheers
    Nov 2010
    BRECHIN
    F13 - ""
    F16 - ABS
    F29 - ABS
    Hope this helps
    cheers very much, will one of those portable code readers be suitable to check for faults? or would it need full diagnostics? thanks
    Nov 2010
    BRECHIN
    checked all the fuses but f13 is empty. no fuse in it???? cheers
    quite a few fuses empty actully, cheers
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    Quote Originally Posted by TimTay View Post
    There fine for reading and clearing faults but for similar money you can get op com of eBay, plugs straight into a laptop and does a lot more. Check the fuses first though
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    Not every holder will have a fuse, but check the ones listed above.
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
