Results 1 to 10 of 11
Thread: Lowering on standard shocks
    N
    Default Lowering on standard shocks
    Hi,
    Well I purchased some PI springs which should lower my 1.8 2004 vectra by 30mm. I did some searching on here and heard that lowering by 30mm on standard (i.e non-sri) shocks would be about the maximum.
    However now I've ordered I found a few more posts describing issues with a 30mm drop on these shocks? Can anyone please advise me? I cant afford new shocks so would have to return the springs if they're not going to be suitable. I would fit them and find out, but once used, the springs cant be returned!
    Cheers in advance
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    I don't know if there would be any difference but i've lowered my GSi using standard shocks and PI 45mm springs and don't seem to have any issues.
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    30mm should be fine on standard shocks, never heard of any problems myself and had none either.
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    I put 40/45 on my standed shocks lasted 7-8 months then the ns one went but think thats down to road conditions put bilstein b8 on and I'm well pleased!!
    N
    Thanks for the replies, but don't all of you have the sri spec shocks? I thought the GSI also came with the SRI spec shocks which are shorter than the standard shocks?
    My issues is I have the standard, non-sri, shocks and I'm unsure if that will cause issues.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by yoclick View Post
    I think that the standard SRi/GSi setup is 10 to 15mm lower than other models so in theory there shouldn't be no difference between the two.
    Regional Organiser - East Region whiskyno7's Avatar
    norwich
    38 Post(s)
    Vehicle : vauxhall signum
    Trim : 2.0t
    Engine : chipped and remapped
    Year : 03
    Mileage : 100k+
    Quote Originally Posted by Hyperhart View Post
    yes i think the gsi/sri are lower'd 15mm. if you go to low watch out for speed humps
    it say's it all
    West
    A 30mm drop on standard non sport springs will be fine, i have done this in the past... any lower than 30mm & you then need to change the shocker as well.
    Regular Member Wolflinn's Avatar
    Camberley
    It does get a bit confusing yoclick.
    I have been reading alot about springs myself latley.
    This is what I seem to have found.
    1. sri shocks are already shorter so can lower springs by another 15mm, no problem.
    2. Some people have lowered by more then this i:e 40/45mm with sri standard shocks, but many do not recommend (saying use b4`s as well)
    3. Standard non sri shocks should be ok with a 30mm drop, but no more.
    4. Age and condition of shocks also seem to matter but, no details on how old is old or amount of miles is considered old worn shocks.
    5. Seems there is a bit of risk in whatever you do, but I expect you will be ok, and if not, I do not think you would lose to much money in re-selling Pi springs second hand.
    Regular Member hagga's Avatar
    kingswinford
    as above... non sri/gsi shocks-30mm.. sri/gsi shocks-45mm.. as for b4's.. when I had pi-45mm springs i couldnt find any b4s listed for the gsi/sri(was a couple of years ago mind )
  1. Lowering springs and shocks
    By owen_999 in forum Handling & Braking
    Last Post: 17th January 2013, 15:51
  2. Lowering spings and shocks
    By mikey2704 in forum Handling & Braking
    Last Post: 1st May 2012, 21:18
  3. new spring and shocks + lowering
    By mikey362 in forum Handling & Braking
    Last Post: 12th September 2011, 13:37
  4. Lowering Springs on SRi With B4 Shocks?
    By nickabbott2008 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2010, 13:28
  5. Lowering Springs on Standard Shocks
    By bizerk in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2009, 01:51
