Results 1 to 10 of 25
Thread: 2004 1.9 cdti 150bhp car has died
    glasgow
    Default 2004 1.9 cdti 150bhp car has died
    2004 vectra 1.9 cdti 150bhp
    car died last night limp home mode error code said egr valve malfunction so stripped and cleaned it and also done boost sensor reassembled and now engine wont start it turns but wont fire up prior to the egr clean car started but wouldnt tick over error code is now p1109 p i have checked swirl bar it is intact it seems as though there is no fuel getting through is there something i might have missed when reassembling egr and boost sensor.
    thanks
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Unless you disturbed the plug onto the common rail, or didn't plug the boost sensor back in, nothing you are likely to have touched.
    glasgow
    thanks mate would boost sensor cause symptom of not firing
    glasgow
    Quote Originally Posted by prof1908 View Post
    thanks
    hi update
    i had misses turn over engine swirl bar not moving at all and high pitched just audable noise coming from bulkhead no knocks or bang when turning over very smoth it as if all valves were open to test starter i put it into gear and it pulled forward so starter is ok
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be the EGR valve is jammed open (this will cause rough idle or engine won't start at all).
    On looking at your profile you have 2004 CDTI so it may be the throttle body. Inside it there are solder joints which crack and cause open circuits. There is a How2 on fixing it. If this is the problem the plate will be closing over because the open circuit will make the throttle body think the engine has been switched off.
    Faulty swirl bars.mechanisms usually don't cause starting problems.
    Gazza4
    glasgow
    Default it alive
    vectra has sprung to life
    original fault code was p0400 befor i started
    here what i did took off egr and boost sensor cleaned and refitted car wouldnt start and had error code p1109 but no p0400 i then checked all connections in engine bay and took off egr valve and stripped it to check solniod operation and refitted it back on car cleared code and tried again same wouldnt start i then disconnected battery left it for about 2 mins recconnected it and it fired up first turn of key.the car has got its kick back and tickover has improved and no flat spot so i guess disconnecting battery would have reset the ecu and restored default to all sensors
    many thanks guys for info and help couldnt have donit without your help
    taunton
    Default fault code p1109
    took car into town today car spanner light came on and car was got going very well got a code as p1109 had a look at the bar on the swirl valve and it still conected but still get this code.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by matt450 View Post
    Drive module may be away. Watch the bar as someone revs the engine past 2,500rpm and the rod should move. If it doesn't then the drive module has failed. The module sits underneathe the manifold and operates swirl flap number 3 which via the rod controls the other ones. If the manifold is the old style then add this to the reapir bill too.
    Gazza4
    taunton
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    thanks bud thats what i thought a mate of mine had a look at my car and he did say the manifold may need replacing at some point
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    No probs.
    Tbh you are lucky the module went as normally if they are working and the manifold needs to be changed, they don't change them. This way you'll be getting a new manifold and drive module.
    Gazza4
  1. Has my Turbo died? Vectra C 1.9 cdti 150 16v
    By Mission1979 in forum Engine & Drivetrain
    Last Post: 10th August 2012, 00:07
  2. 1.9 cdti mpg (150bhp)
    By Aikon58 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2011, 23:24
  3. 2004 150bhp 1.9cdti flywheel question
    By veccyjoe in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2010, 21:59
  4. 150bhp cdti
    By dirty-diesal150 in forum Diesel Engine related
    Last Post: 19th March 2010, 21:03
  5. is my cdti 120 or 150bhp
    By LISAJANE0410 in forum Engine & Drivetrain
    Last Post: 27th March 2008, 22:37
1.9 cdti 150bhp dont turn over
