Results 1 to 10 of 11
Thread: Washer/pump/dohh!
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Washer/pump/dohh!
    Hi all..my windscreen washer pump seemss to be on the blink..it hardly gets enough pressure to 'wash' the bottom 3 vinch of the screen and nothing happens at the back.
    Any ideas???
    Sep 2009
    Glasgow
    might not be the pump could be the filter.
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    thanks for the reply...any idea where the filter might be??
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    Quote Originally Posted by nikroc View Post
    On the pump, try and find a join in the pipe where the non return valve is, on a vec b its by the near side bonnet hindge, disconnect the pipe and use a battery tyre inflater or a low pressure air line and force air back down to the washer bottle, this will clear the filter but only short term as the washer bottle will require flushing.
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Derrr..any ideas where it might be on a 2003 c,2t?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    There's a guide in the 'how 2' section!, remove the l/h three screws for the arch inner lining as shown & flip out the hoses clipped onto the container, pull out pump, the filter may come out with the pump or may stop in the bottle, clean with water & old tooth brush.
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Thanks for the replies..i shoulda searched the forum BEFORE i posted..
    Found the how to last night and it was sorted by 9 this morning. I removed a inch n half lump of blue snot from the filter!!!!
    Flushed through with two kettles fulla boiling water.
    Norwich
    Trim : SXi
    Engine : 2.2
    I cleaned mine out about 2 weeks ago as I had the same problem and now it has done it again.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by the_wave_rider View Post
    same here but after re checking the filter it was clean!, I ended up having to connect the pump up direct from the battery with the pump sitting in a tub of water, then back flushing the pipe out to clear crud .
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Moved from General Chat to relevant section..
    General Chat Any non-car related chat, but still of some useful relevance to people i.e. not idle chat, comedy or spam threads - use the relevant sections for those.
  1. Winscreen washer pump
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2012, 11:51
  2. water washer pump
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 13:39
  3. Washer Pump
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2008, 13:29
  4. washer pump
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2008, 15:37
  5. screen washer pump
    By simon1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2008, 16:40
