Thread: Adjusting coilovers
    Regular Member Friel's Avatar
    Ireland
    Default Adjusting coilovers
    I'm getting in a set of coilovers during the week, but ill be at work when the fella is putting them in. So ill have to adjust them myself when I get home. How do I do it? Is it a big job?
    southampton
    eaassssyyyy, take wheel off, loosen lock nut, wind it down to where u want it then wind the nut the springs sat on down to your desired height then just nip the lock nut up. use a gauge to make sure the spring is at the same height both sides n grease threads to prevent corrosion. maybe a half hour job.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Just Ask The Guy To Set Them Up @ What He Thinks Will Be Aryt Clearance Wise..Thats If You Want Them That Low...Probs Wont Be A Million Miles Away From Where You`d Want Them
    Ireland
    Quote Originally Posted by alex View Post
    What do you grease them with?
    Aug 2010
    Dundee-Motherwell
    Can Of Spray Grease Would Be Easiest
    You Are Greasing The Threads And Nuts
    Is This The FK Coilovers ?
    Ireland
    Yeah that's them. The cars only a run around, so buying anything more expensive would of been crazy.
  1. Adjusting Handbreak
    By Alank in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2011, 23:26
  2. headlights not adjusting ??
    By blackcountryroy in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2008, 21:00
  3. adjusting headlights
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 20:29
  4. Boot adjusting
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2008, 20:16
  5. adjusting mirrors
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 00:09
