Thread: wheel bearings
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default wheel bearings
    Is there any reason why the r ear wheel bearings cannot be pressed out and replaced???
    May 2008
    Tyneside
    The hub is a factory sealed unit which incorporates the ABS reluctor ring and sensor. Easy to just bolt a new unit on and I only paid £55 for a FAG OE one on ebay.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as tridley says sealed unit and an easy fix
    Regular Member Jezzy's Avatar
    S.E
    If you think you need a new rear wheel bearings, is it because of a rumbling noise? If so, that's usually caused by tyre wear rather than a faulty bearing.
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I have changed the tyres twice over the time i have had the car... Brakes stripped and cleaned,new discs and pads..noise still present..despite sailing through 3 mots..hmmm
    Jul 2009
    Engine : 20 Dti
    have you checked for any play at 12/6 o clock,9/3 o clock
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    literally just gone through an mot...nowt mentioned...?????
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Unless there is play it wouldn't fail the mot.
    The Vec C/signum bearings don't tend to have play although they can whine like hell. What you have to do is jack the car up and listen closely as you turn the wheel, the rumbling bearing will feel different to a good one
    Jul 2009
    Engine : 20 Dti
    I changed my r,n,s because of a ticking noise that drove me mad new hub assembley cured it.no play in the old unit
  1. wheel bearings ????
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 20:52
  2. Wheel Bearings
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 13:52
  3. Wheel bearings
    By Days of thunder in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2008, 08:26
  4. Wheel bearings
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 8th April 2008, 10:08
  5. Wheel bearings - again
    By kinger in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2006, 20:32
