Results 1 to 10 of 13
Thread: Slight hesitation/judder when accelerating 1.8 petrol
    Sep 2009
    ipswich
    Default Slight hesitation/judder when accelerating 1.8 petrol
    Hi... I have a 1.8 petrol estate which over the past two or three weeks has developed a slight judder/hesitation whe depressing the throttle upon acceleration... its sort of a bit jerky. Its slowly getting more pronounced. Its fine once you back the throttle off to cruise. Its not the clutch juddering (which it also does!). Its the engine.
    Any ideas please?
    Im going to change the plugs and air filter and have a look at the throttle body to see if its gunked up....
    I need to do a long journey this weekend so im a bit worried about it...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Not 100% but I think there is a clutch problem which affects the 1.8's and I think that is a symptom but i'm not too sure.
    Gazza4
    Sep 2009
    ipswich
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    is that even once the clutch has been comletely engaged and the foot isnt even on the pedal?
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Not had a judder like that, I did have a slight hesitation more like a flat spot, did the airbox mod and fitted K&N and it seems to have gone away.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by waterbourne View Post
    Like I said m8 I'm not 100%, I don't know what exactly happens only that there is a clutch problem. It may only affect the VVT's ('06 facelift only).
    Gazza4
    Sep 2009
    ipswich
    these EGR units.... scuse my ignorance but to petrol engines have them too?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I believe they were deleted on the 2004 1.8's and later.
    Gazza4
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Yours is an 05 so it does not have an EGR valve.
    Sep 2009
    ipswich
    ok thanks...
    is there any issue with throttle butterfly caking up on these?
    Sep 2009
    Audley STAFFS
    Any ideas please?
    IF YOU DO your long journey, put a good shot of redex injector cleaner in before you go,, but as its developing it could be as well to check coil pack.
  1. Legendary Judder/Hesitation!
    By wotsthestory in forum Y & Z30DT Specific
    Last Post: 24th July 2012, 07:28
  2. help please .... Hesitation when accelerating
    By amir2300 in forum Engine & Drivetrain
    Last Post: 12th July 2011, 15:58
  3. 1.9 CDTI 120 Hesitation Judder.
    By CDTI120SXI in forum Engine & Drivetrain
    Last Post: 8th July 2011, 17:45
  4. Vectra C 2.0 DTI Judder when accelerating????
    By bigfella in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2010, 15:36
  5. Slight hesitation
    By AJA in forum Engine & Drivetrain
    Last Post: 28th April 2007, 08:30
vectra juddering when accelerating
vauxhall insignia juddering when accelerating
vectra c 1.8 hesitation
vauxhall zafira juddering when accelerating
zafira juddering on acceleration
vauxhall insignia 1.8 juddering
vauxhall vectra judders when accelerating
slight clutch judder vectra
vectra hesitation on acceleration
https:www.vectra-c.comforumshowthread.php126888-Slight-hesitation-judder-when-accelerating-1-8-petrol
astra 1.8 hesitationvauxhall astra 1.8 2004 hesitate a 2kastra h juddering vvtinsignia engine juddering 1.8 petrol when pulling offzafira b judder on accelerationvauxhall zafira juddering problemsvectra c low end ecceleration hesitationvectra 1.8 petrol clutch judderwhy 1.8 petrol zafira b is jerkyvectra hesitation on acceleration when coldvauxhall zafira 07 juddering when acceleratingjuddering hesitation on accelerationvauxhall vectra hesitate vectra c slight hesitation on accelerationvectra judders when slow driving
