Thread: Battery light on, 14.4V at the battery!
    Wiltshire
    Default Battery light on, 14.4V at the battery!
    I have a 2005 facelift 1.8 Vectra. Last November the battery light came on and on testing the voltage at the battery I had about 12v. Obviously not charging so ordered a new alternator which was fitted a couple of weeks ago. The battery light fault was intermittent and if it came on while driving I would go into the hidden menu and read the voltage on the display which would also read about 12v. When the light went out it would read about 13.7v.
    With the new alternator it was charging at 14.4v. Last night the light came on again but the display showed 14.4v. When I got home a put the voltmeter on the battery which also read 14.4v but the light was still on!
    This morning the light is out and battery is charging at 14.4v.
    Can anyone shed any light on this?
    Cheers. Matt.
    East Midlands
    ?Did you get a brand new alternator or a recon one,i once had a similar fault as yours and it turned out to be the voltage regulator,needs bench checking by a Auto spark if you have one near where you are,
    Wiltshire
    Alternator was brand new! I'll see if I can findan auto spark to test it, if not might see if I can get it replaced under warranty!
    Jul 2009
    Brighton
    Is the battery OK? If it's not holding it's charge, that may cause the light to come on.
    From personal experience, replacing the alternator is usually followed by replacing the battery.
    Worth testing anyway.
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  4. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  5. battery light
    By ryhnok in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2011, 20:30
