Results 1 to 10 of 15
Thread: how can I measure boost, air mass and air-fue ratio
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    Question how can I measure boost, air mass and air-fue ratio
    guys is there a program i can buy for my laptop that will allow me to measure the boost pressure, air mass and the air to fuel ratio.. I know i can get them if i take the car to a rolling road but i want to be able to read/record the data live on a laptop.. I am not wanting to add gauges just for this, i have boost gauge although not fitted.
    any ideas?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Dont quote me on this nige but i think this is a feature on a tech 2 . give plasma a ring/pm he should be able to confirm or not
    Regular Member signumturbo04's Avatar
    SCOTLAND
    i'm 99% sure its on op-com too
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by signumturbo04 View Post
    Looked at mine today using that
    Jun 2009
    South Coast
    6 Post(s)
    what, i can measure all those with opcom? i guess i need to have a closer look at it, not sure where i look to get those figures recorded while car is in motion though..
    Engine : 1.9 CDTi
    Also you can buy a bluetooth ELM427 interface and get app's which will read all that sort of data (And G forces)
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I'm sure you can access a hidden menu on full can cars BC's that tells you all that info live. No need for opcom or Tech 2.
    Jun 2009
    South Coast
    6 Post(s)
    now that sounds even better... my car is a chassis 5, will I have that option and if i do i don't suppose you could give me a tip as to where to access it please mate..?
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by Caveman_nige View Post
    Click on engine once you put your car details in.
    Then measuring blocks i think it is.
    I tried to do a regen in programming,but it wouldn't do it,but that could be because my laptop is old and only has usb 1.0 on it,so it can't read the info needed to do it quick enough
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Try search in op-com under:
    -engine
    -output test
    You will find boost pressure here. Maybe air mass and air-fue also.
    On boost pressure you can look at "boost pressure comand" and "boost pressure". Thise are show as kpa (100 kpa = 1 bar = 14,5 psi) You might adjust for barometric pressure. So if it shows 240 kpa, boost pressure are 240 kpa -100 kpa (barometric pressure) = 140 kpa/1,4 bar.
  1. Wide ratio g/box in an Sri ?
    By 2MUCHGAIN in forum Engine & Drivetrain
    Last Post: 18th April 2012, 18:49
  2. Pulse Ratio Boost Pressure Solenoid Valve
    By iwtand in forum Y & Z30DT Specific
    Last Post: 12th March 2012, 19:57
  3. Short measure at the pump!
    By Old man Jimbo in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2011, 17:29
  4. Please measure you knobs
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2011, 20:45
  5. Anybody know the gearbox ratio for the F40 box in the VXR ?
    By MrLOL in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2009, 14:36
