Results 1 to 2 of 2
Thread: signum clutch problems
    BIRMINGHAM
    Default signum clutch problems
    hi all. i have a 56 plate signum. last week i got into my car pressed the clutch down to the floor and started the car. it made a grinding sound and the clutch pedal stayed almost to the floor and wouldn't alow me to select a gear. i turned the engine off and physicly lifted the pedal up and all was ok and back to normal. however, today it happened again.
    durring these problems the car is changing gear fine and smooth..
    any one had any simular problems or any idea's
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Just idea could be air in your clutch hydraulic pipe or a sticking conical slave cylinder just a few ideas mate and what's your brake fluid like as your clutch will take a feed off there to your bell housing so make sure there is no leaks or no fluid in the reservoir
  1. Clutch problems ?
    By hippo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 22:39
  2. Clutch Problems??
    By trublu24 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 13:18
  3. Clutch Problems
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2008, 14:47
  4. Possible Clutch problems??
    By jazzy_2.2dti in forum Engine & Drivetrain
    Last Post: 11th February 2008, 20:48
vauxhall signum clutch problems
signum clutch
