Results 1 to 10 of 14
Thread: CD70 into a 2003 Vectra
    Aug 2009
    Copenhagen
    Vehicle : Caravan
    Trim : Cosmo
    Engine : 1,9
    Mileage : 243000 km
    Default CD70 into a 2003 Vectra
    Hi you guys,
    One of my friends just bougt a 2003 Vectra C with the NCDC naviation installed and colour display.
    Now my Vectra from 2006 is installed with the CD70 Navigation.
    I'm about to buy a DVD90 Navigation, and want to give my CD70 to my friends, before promising him anything i would like to know if it's possible to install my CD70 into his car?
    Mine is the faceliftet model his is not.
    Hope you can be helpful ;o)
    Administrator plasma's Avatar
    On the Forum
    556 Post(s)
    Engine : 150
    Mileage : 74000
    Not as it stands no, but you can get a wiring harness and change some other bits (CIM) steering wheel controls? and some other bits.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Its not impossible...
    He will need:
    Screen (to facelift CID or Satnav ready GID)
    Radio
    Convert ISO to Fakra
    RGB lead
    ECC panel (if the car has Electronic Climate Control)
    Satnav aerial (aftermarket for 10£ on ebay (blue fakra plug)
    If steering wheel controls also going to work
    Facelift steering wheel
    Facelift Airbag
    CIM
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    also look what PHE have written among othe here: http://www.vectra-c.com/forum/showthread.php?t=107126
    Aug 2009
    Copenhagen
    Vehicle : Caravan
    Trim : Cosmo
    Engine : 1,9
    Mileage : 243000 km
    I dont he needs the switches on the steering wheel to work, if he wants i have my old steering wheel laying around as i've change mine to the VXR one
    Just to make things clear he has navigation installed now i think it's NCDC2013 with color display.
    Will he still need to change his screen and sat arial also?
    He does not have the climate control, so that should not be problem.
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    yes still need to change the display and aerial.
    he can maby use the arieal, if he can get the gps plug converted to fakra.
    (its not enough just to change the steering wheel.. also needs to change the CIM)
    Aug 2009
    Copenhagen
    Vehicle : Caravan
    Trim : Cosmo
    Engine : 1,9
    Mileage : 243000 km
    CIM?
    Kenp - do you know a place where you can get the the converter?
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    CIM -> Steering Wheel Module
    Det er Rat stamme modul der hvor viskerarm mv. er sat ind.
    Look on ebay.. you probaly need to buy 2 adaptors and the connect the correct wires together.. (as i did on my NCDC retrofit).. but shouldt take more than 20 minuts to make.. when you have them..
    I know you need 2 SOT leads
    http://cgi.ebay.co.uk/SOT-122-Vauxha...item3cb049b4f4
    http://cgi.ebay.co.uk/SOT-078-VAUXHA...item5195750b6f
    Edit: it should be those SOT leads.. but dont look like they have wires to all pins, as that whould be a very good start, maby needs to be found on ebay.
    Regular Member Robsey's Avatar
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    Are you sure you need to change the CIM ?
    I have a 2003 CIM and 2003 BCM in my Cavalier (Vectra-A), which quite happily work with my CD70, GID, Scroller wheel controls and 2005 light switch.
    If it is just the Infotainment system that is being changed, then you will need
    1) SOT122S autoleads cable
    2) Fakra / aerial adapter for the radio
    3) Patch GPS aerial with Fakra connector for sat-nav
    4) and a minor rewire of the screen connector and CAN wires for the head unit
    5) Physical modification of a facelift screen surround if it is a CID.
    GID is not a wide screen unit - if I remember correctly, and so will fit a pre-facelift surround.
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Robsey -> only from what PHE have written in the thread im linking to.
  1. Hi, 2003 vectra c
    By kristinn in forum Introduce yourself.
    Last Post: 1st February 2014, 15:55
  2. For Sale: vectra 2.2 ls 2003
    By jpbroad1970 in forum Cars for sale
    Last Post: 4th September 2012, 23:34
  3. Vectra GSI 2003
    By icie69 in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2010, 22:09
  4. 2003 (53 reg) vectra sxi 2.0 dti
    By ADAM123 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 26th November 2008, 19:18
  5. 1.8 Vectra Sri 2003
    By Gregg in forum Cars for sale
    Last Post: 7th October 2008, 12:04
