Results 1 to 10 of 18
Thread: Someone help!!! Please.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Default Someone help!!! Please.
    In the middle of changing rear discs and pads. Calliper has already been taken off and the old pads removed.
    Can someone please tell me an easy way of undoing the calliper mounting bolts so that I can take the discs off. There seems to be no space to move the rachet to undo the bolts.
    Also the piston is refusing to rewind. Do I have to apply a lot of force to rewind (don't want to knacker anything). By the way, this is the tool I am using http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    Thanks.
    P.S. I posted this earlier on today without a reply.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    the caliper rewind tool there should do the job, you are using the supplied backing plate to give you the pressure on the piston i assume?
    Its been a year since i did my disks and pads but i used a breaker bar pointing it out under car and that did the trick.. be sure you use the correct socket though as you do not want to round those suckers off.
    Birmingham
    Quote Originally Posted by 123rado View Post
    Thanks.
    HI,
    The trick to rewinding the piston is to rewind anti clockwise. Which means when tightning the rod in to the piston THE DIRECTION SHOULD BE ANTI CLOCKWISE. Specially on the back wheels if you take the hydro pipes off they will still refuse to go back in until an anti clockwise movement is not provided.
    Make sure you're not pressing inwards pressue but rotating anit clockwise.
    I hope this helps you.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Quote Originally Posted by nasir600 View Post
    HI,
    Well, the how 2 I am following said clockwise direction. Am I missing something here? http://www.vectra-c.com/forum/showthread.php?p=188139
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Quote Originally Posted by Caveman_nige View Post
    Thanks but car is not on ramp and there is just not enough space from the ground.
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    i did not use a ram mate, i did this on my driveway.. axle stands and a trolley jack was all i had..
    Administrator plasma's Avatar
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    turn the steering wheel full lock left or right, gives you more room Also its clockwise to turn the caliper
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Quote Originally Posted by plasma View Post
    he is doing the rear disk and pads mate.... unless he has rear wheel steering...
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Will continue tomorrow. Already dark outside. Thanks for the tips.
    Regular Member Jezzy's Avatar
    S.E
    HI,
    No mate, it should be clockwise - unless you have an old shape Ford Mondeo estate, where it's clockwise on one of the rear wheels and anti-clockwise on the other side.
