Thread: 2006 Signum 2.2 engine fault codes! Help please :)
    Jul 2009
    Wirral
    Default 2006 Signum 2.2 engine fault codes! Help please :)
    HI all, my trusted 2.2 direct engine has 3 fault codes and Im not sure were to begin. Ive looked up and may are saying the fuel pump and regulator need replacing but I thought Id check on here first.
    My car just went into limp home mode/engine light on after 45mins of driving. If i switch the car off and restart it drives ok, but after a few seconds the lights come back on
    The codes are
    P0130, no plausibility between o2 sensor 1 and bank1 and same on o2 2.
    P1191-5a, fuel rail pressure sensor circuit low.
    P0303-01, cylinder 3 misfire detected.
    The car had a full service about 6 months ago, (new fuel filter and plugs). do you think its just a spark plug failure? And how do you test a spark plug if so?
    Thanks in advance.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    er 1 is a spartk plug prob gone one is oexgen sensor i think and also the other looks as if your fuel pump is on its way out dont hold me to them but i think am not far away
    Jul 2009
    Wirral
    Thanks, will buy a spark plug and see if that code disappears, and try and find a oxy sensor and pump on ebay
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by t13con View Post
    The codes are
    Thanks in advance.
    I don't suppose you were towed home the other day by the AA and live in Bromborough? Cylinder 3 I would say as either a sparkplug or the coilpack. I'm not sure on the other two codes though.
    Jul 2009
    Wirral
    HI, no it wasnt, luckily for me I was in wallasey Village when it went into limp home mode. Im about to swap the plugs to see if that fault code disappears. Idont see how one problem (i hope) could lead to 3 fault codes?
    Oct 2007
    estonia
    I bet the main cause of these DTC-s are the high pressure fuel pump. The misfire DTC is definately from that. And when an engine developes a misfire, an O2 sensor DTC may easily occur.
  1. Engine Fault Codes
    By spukeyyy in forum Engine & Drivetrain
    Last Post: 17th April 2011, 21:51
  2. Replies: 13
    Last Post: 20th May 2010, 20:09
  3. Signum 2.0 dti fault codes
    By Babycake in forum Engine & Drivetrain
    Last Post: 7th April 2010, 11:25
  4. New car fault codes and engine management
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2009, 18:47
