Thread: Boost sensor & EGR valve
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Boost sensor & EGR valve
    Would i be ok using WD40 to clean both of these? I know carb cleaner is best but i have run out and cant be bothered going to get more.
    Liverpool
    hmmmm, its wont be very good tbh, WD40 is more of a lube/penertrating spray
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    it will clean it, but not as good as a crab/brake cleaner would. and since your going to the effort of cleaning them you may aswel pay a couple of quid and clean in properly
    Jul 2006
    Northampton
    Trim : Sri
    Ah! I have brake cleaner, didnt know that would be safe to use
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Danwells72 View Post
    its basically the same stuff mate
    all id say is let them dry for about 15-20 mins before connecting them back on the car
    Regular Member Dazzy2006's Avatar
    Notts
    As above - brake cleaner should be fine but dont use wd40 as its an oil and soot will stick to it
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It would defeat the purpose if you were to use WD40 as it's the oil in the turbo system that makes the sensor give false readings in the first place.
    Glasgow
    ive been using a similar stuff to the wd40 as i didnt have carb cleaner and it does fine mate, but as these guys say, its not the best to use.. but does work as long as you scrape everything off.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by paul_sri150 View Post
    Use carb cleaner. WD40 is more more greasing moving parts.
    Gazza4
    Jul 2006
    Northampton
    Trim : Sri
    Well this was done yesterday and i used brake cleaner. tbh i think it worked a bit better but cant be sure. either way car is now running nicely but i did notice a few things im not happy with from when i went to mij!
  1. z20net boost control valve sensor
    By dj1 in forum Engine & Drivetrain
    Last Post: 25th April 2012, 13:31
  2. 1.9 Boost Sensor and EGR Valve clean
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2011, 16:16
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
  5. EGR VALVE and BOOST SENSOR cleaned today!
    By VXR CDTi in forum Engine & Drivetrain
    Last Post: 11th November 2008, 23:20
how to clean a corsa vxr boost sensor
