Results 1 to 10 of 13
Thread: Holding onto revs on gear change...does yours?
    Regular Member Knuckle's Avatar
    South
    Default Holding onto revs on gear change...does yours?
    I've found that when i change from 1st to 2nd and 2nd to 3rd, sometimes the revs keep climbing another 200rpm or so or just hold at what they are for a second....does yours?
    Guessing its just a poopey electronic throttle...much prefer a good old wire!
    No, never seen that
    Then again I tend to release the gas and then depress clutch
    I used to try and match the revs during gear changes, don't bother any more
    Blantyre
    Yes mine does that, and there are a few others on here that have also mentioned it,
    You both have 2.2 petrol engines...
    If still under warranty report for diagnosis
    Most likely come back as no fault found, but at least it is on record for future failure which can then be backdated
    Blantyre
    Not just the 2.2 though mate, few others there to
    http://www.vectra-c.com/forum/showthread.php?t=120302
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Mine does it too, test drove another Vectra, same...
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    They role out of the factory like that, its part of the fly by wire. Its mapped in to supposedly smooth out city/stop start driving.
    liverpool
    Yep my direct does it , annoying at first but soon get used to it
    South
    Cheers guys , I chEcked for fault codes using the techniques listed and nothing came up. Thought the throttle body might be caked up or something. Right stupid idea if you ask me! It means I have to slow down my gearshifts as the synchro doesnt really like it at the moment hoping the gearbox oil change will resolve that though
    Tried in my car
    Tried on the level, uphill, and downhill
    No change in the revs
    Tried in a relatives car, a 1.8
    I noticed a very slight increase on releasing the gas pedal, at below 10mph, but only in 1st or 2nd gear
    Went back to my car
    Couldn't recreate it
    So, what about the 1.9 diesel, does it do it?
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. 1st to 2nd Gear Revs Hold
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2010, 19:42
  3. revs not dropping when changing gear
    By billpayer in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2010, 12:36
  4. 2003 2.2 sri dti high revs between gear change
    By hindzy in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 12:14
  5. speed and revs in gear 2
    By Mike57 in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2006, 11:15
revs increase when chahging gear vectra c 2008
vectra c holds revs between gears
