Results 1 to 3 of 3
Thread: Wheel & Tyre size
    Norwich
    Trim : SXi
    Engine : 2.2
    Default Wheel & Tyre size
    Guys
    I'm assuming this will be ok but I'm currently running 225x40 tyres on my 18,s but the wheels I'm getting off my mate have been running 215x35.
    I should be able to stick my tyres on his wheels with no probs?
    Regular Member paul.sessions's Avatar
    leighton buzzard
    yes i cant see no problem.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    It depends if they are the same eg 8j. 225s are a good fit on a 8j wheel I had 215 on my standard wheels as they were 7j. if you look inside of the wheel (when it is off the car) you can see stamped what size they are. They are stamped where the wheel sits on the hub of your car. (center hub bit of ya wheel). There is a load of info on the interweb just do a search for the correct tyer size for an 8j wheel or 7j etc etc. then you cant go wrong.
    Im running with 225 40 18 on my 8j 18" et38s
  1. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  2. tyre size on standard wheel
    By i5aces in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2011, 01:46
  3. What size tyre can i use on 17inch wheel
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 19:16
  4. wheel and tyre size
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2008, 20:09
  5. Wheel/tyre Size
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2006, 20:01
