Results 1 to 3 of 3
Thread: problem with brakes
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI160
    Year : 2012
    Default problem with brakes
    only happens on 1st cold start of the day - when applying brakes for the first time they don't work correctly - spongey, not biting as they should. Subsequent use of the brakes are fine. A bit disconcerting when approaching that first junction of the day.
    Anyone had this problem or know what might be causing it?
    edit: wrong section sorry. please move.
    Aug 2010
    Leeds
    You may have air or moisture in brake fluid which requires changing, If not been done in the last two years replace.
    Also a full brake check is required do check pads for glazing and caliper slides ok.
    Brake fluid is the one single item on brakes that gets missed the calipers get painted all new brakes get done and a simple fluid change gets missed.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI160
    Year : 2012
    cheers, i was thinking it might be something to do with the fluid too. probably about 2yrs since it was changed.
    just passed MOT last week, so there can't be much wrong with the brakes, but worth checking out. Horrible experience when the car doesn't stop as you expect
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. Problem bleeding brakes
    By pfj in forum Suspension, Wheels & Brakes
    Last Post: 29th August 2011, 19:57
  4. problem with ABS,brakes & electronic
    By jack m in forum Suspension, Wheels & Brakes
    Last Post: 4th April 2011, 23:19
  5. Problem with brakes
    By sri22dti in forum Suspension, Wheels & Brakes
    Last Post: 25th July 2008, 23:03
