Results 1 to 3 of 3
Thread: Engine squeal on startup
    Oct 2009
    newport
    Default Engine squeal on startup
    Hi guys
    Starting to get a very brief (2-3 seconds) squeal when i start the engine, it goes then straight away. Have read that it could be the auxilary belt or tensioner? Before i start spraying belt slip or wd40 about are these easy parts to change for a novice or would i be better off taking it to a garage?
    cheers!
    Aug 2010
    Leeds
    That all depends or your own abilities with spanners are you competent or not?
    Yes it's easy enough takes a little time and can save you a few quid.
    If you have no idea best pay for the labour to fit.
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Could be starter motor if it's a low pitch squeal ? it will be the bush in the end of starter gone dry take it of and grease it and that will stop it!
  1. loud squeal around 2k rpm
    By skene in forum Engine & Drivetrain
    Last Post: 21st August 2012, 13:19
  2. Got Squeal ??
    By wardy23 in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2012, 22:42
  3. Brake squeal
    By Samdy Gray in forum Suspension, Wheels & Brakes
    Last Post: 19th December 2011, 10:22
  4. Brake Squeal
    By yoclick in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2009, 19:32
  5. squeal
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2007, 20:57
