I'll be opening up the engine sometime next week or the week after that to replace the injectors. We'll also inspect the valve clearance and adjust accordingly.
Does anyone know the diameter of shims used on the Y30DT engine?
The previous did the cambelt but not the valve check at 148,000km(92k miles).
I think this could be the reason why it sounds so clacky and tickety on tickover. The injectors were bad on my old 3.0 too and it sounded much nicer.
http://www.youtube.com/watch?v=LNxP-EN8Uhg
http://www.youtube.com/watch?v=mP8f6idrDBw
Yours as well!!!, mine sounds "clackey and tappetey" more from cold, when its warmed up after a run it sounds much better. I am pretty sure the injectors are ok, as it seems to run and go well
I've looked on EPC and there are a whole range of different sized valve shims for your engine, starting at 2.70 mm and going up to 3.30 mm, increasing by 0.02mm each time.
