Hi All,
After only a few months of ownership of a 06 plate 1.9 cdti SRI Vectra I have started experiencing a loss of power at low revs i.e 2000 and under.
As result of this I decided to give the car a quick service and a general once over, on doing this I noticed that a bar (that I believe is called a swirl bar?) has become loose in front of the glow plugs and was lieing on its side. After completing I reset the service indicator and the engine management light came on (not on before)- I have now had the computer read and fault code P1109 (Swirl actuator).
I have a couple of questions-
1. Would this fault code result from the bar- remedy new inlet manifold £250 or would I need to replace the swirl actuator as well £200?
2. Does anything else need doing the same time i.e cambelt, tensioners etc (car mileage approx 85000)
Your feedback would be appreciated as this lloks like a very expensive job to have to do just after christmas.
Many Thanks
Jenks
