Results 1 to 10 of 15
Thread: Swirl actuator fault P1109
    VALLEYS BOYO!!
    Default Swirl actuator fault P1109
    Hi All,
    After only a few months of ownership of a 06 plate 1.9 cdti SRI Vectra I have started experiencing a loss of power at low revs i.e 2000 and under.
    As result of this I decided to give the car a quick service and a general once over, on doing this I noticed that a bar (that I believe is called a swirl bar?) has become loose in front of the glow plugs and was lieing on its side. After completing I reset the service indicator and the engine management light came on (not on before)- I have now had the computer read and fault code P1109 (Swirl actuator).
    I have a couple of questions-
    1. Would this fault code result from the bar- remedy new inlet manifold £250 or would I need to replace the swirl actuator as well £200?
    2. Does anything else need doing the same time i.e cambelt, tensioners etc (car mileage approx 85000)
    Your feedback would be appreciated as this lloks like a very expensive job to have to do just after christmas.
    Many Thanks
    Jenks
    Administrator plasma's Avatar
    On the Forum
    565 Post(s)
    Engine : 150
    Mileage : 74000
    Normally P1109 happens when the actuator gets jammed from moving due to the crud in the inlet. Normally the actuator survives and is ok, (Vx recommend to change this whilst changing the inlet manifold due to it learning the range of movement to opearate and then setting it for the life of the actuator but many ppl have NOT changed it and had no adverse affects)
    85k you say,? I'd of changed the cambelt at 60k personally, so yes get it done! dont forget to change the waterpump too.
    Regular Member Craig1985's Avatar
    harwich essex
    Might aswell do cambelt, tensioners, water pump at the same time
    harwich essex
    Vxl only wanted £297 for cambelt change and tensioners but want £590 for cambelt and waterpump? Sound an expensive pump to me
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If in doubt get the whole lot changed m8. You will pay the same labour twice if you get the manifold and drive module replaced at different times.
    Gazza4
    Sep 2009
    middlesbrough
    Hi mate if you have a look where that bar is and get someone to sit in the car and rev it, look at the 3rd hole along, when the car is revved this should move, a bit like a servo, if this moves you don't need a new actuator, mine is getting done on Tuesday, I got a new inlet manifold, gasket, cambelt kit and waterpump from autovaux for £300 and the labour at a local garage is £200, vauxhall say change the cambelt at 100k but alot of people on here change them earlier, if your having the manifold done u might aswell do the cambelt as your in there anyway
    Sep 2009
    middlesbrough
    Also there should be no extra labour to change the waterpump
    VALLEYS BOYO!!
    Thats great! Thanks for all your replys - was a bit shocked to see how quick I had reponses as I am a member of VVOC and that can take days!!
    Quote Originally Posted by durham4416 View Post
    Whats is Autovaux? a website , shop or garage?
    Jenks
    Sep 2009
    middlesbrough
    Type autovaux into google, phone number is 01924376003, it's open Saturdays
    VALLEYS BOYO!!
    Nice one cheers
  1. Swirl actuator
    By carl78 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 11:44
  2. Fault Code P1109
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2010, 20:53
  3. Fault Code P1109
    By SSM in forum Engine & Drivetrain
    Last Post: 22nd January 2010, 11:56
  4. P1109 fault code
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2009, 17:35
  5. Swirl pot actuator
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 21st November 2009, 01:00
https:www.vectra-c.comforumshowthread.php126661-Swirl-actuator-fault-P1109
how to vectra 1.9 cdti swirl actuator change site:www.vectra-c.comp1109 62 opelp1109 vectravectra c not as much power through rev range site:www.vectra-c.comp1109 zafira no electrics
