Thread: Grinding Noise
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    Default Grinding Noise
    Hi guys, just came home from work earlier and had the windows down in the car and as i was pulling away i could here a grinding/catching noise with every revolution of the wheel, one that gets faster/slower with your speed. I detected it coming from the passenger side, so when i got home i took the wheel off and stuck my head under the wheel arch and rotated the brake disc i thought it maybe something catching on the disc/pads, but the noise is coming from where the axle goes into the gearbox (it looks like the gearbox, on the passenger side), at a certain point on every revolution it makes a rubbing/grinding noise.
    I'm a bit concerned, hope were not talking mega bucks here, my Network Q warranty ran out, i only have the 3rd year manufacturers warranty left. I hope the problem will be covered?
    Any ideas what could be wrong?
    Russ
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    sonds like the inner cv joint from what you describe , although i may be wrong and as thats a general wear and tear item i dont think your warranty will cover it mate as i say hopefully im wrong! if it is that then they are not that expensive to repair
    Jul 2006
    Mexico
    i place my bet to the wheel bearing.. i just changed mine and the symptoms were the same.
    in my case the sound came from the drivers side (cause i live in mexico and my drivers side is your passenger side)
    also i thought at first it was from the gearbox but fortunately it was the bearing.
    To be sure you will need to release the driveshaft from the wheel so it runs alone without any friction from the gearbox.
    my car had about 60000km when the noise began.
    Jul 2006
    Mexico
    i can describe the sound as an annoying "HUM-HUM-HUM" that increase the speed and makes it very very unpleasent between 60 and 80kph. also at slower speeds in quiet places such as underground parking lots
    PRESTON
    Trim : GSI
    Actually when i went to my car the next day, all fired up to take it to the stealer, it didn't make the noise anymore i couldn't exactly go and ask them to listen to a noise that wasn't there. No doubt the problem will rear its head again next january when my warranty runs out! , thats assuming the problem would have been covered anyway.
    Russ
    Jul 2006
    Mexico
    well thats great.. hopefully it was a bad day but wont happen again
    Now in Girvan Scotland
    Default mine is new brakes
    As the title says "mine is new brakes" at the front making the noise, as they were fitted by a spanner (actually he is a motor engineer and a ****** good one) it is going back in a few hours for a check up. but they are screeching when coming to a stand, cant be the bearing (I hope), this has just been done, suspect build up of old brake dust between the ball joint and the shield as the discs are new also, they would be close to the shield with little or no gap for the dust to disperse adequately. I sometimes blast mine with a pressure washer, this cleans the stuff away but as the discs are new, it is not clearing this away at the moment and my mate will take another look later. Hope this helps you with yours.
    did he assemble the pads into the calipers with copper grease??
    that would cure what you are experiencing, the brake squeal..
    It shouldn't be dust as if he's just fitted new brakes and he's worth his salt he'll have cleaned it all way from any surfaces that matter.
    overslept after nights so car didnt go in, and yep copper grease iclearly evident and he has told me that he is now busy for two weeks, grrrrrrrrrr, he also told me they took the whole thing apart and blasted the dust away with pressurised air
    well that's very poor practice anyway
    the brakes don't contain asbestos like they used to, but even so the use of compressed air to blow away the dust is a big no-no..they should have used a brake cleaning spray..far safer way of doing it without breaking HSE regs.
    i'm getting a bad feel about this chap that did them for you now unfortunatly.
    try somewhere else..
  1. grinding noise turning right
    By jon ixi in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2015, 12:08
  2. LOUD grinding noise?
    By UncleMelon in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2012, 11:21
  3. grinding rubbing noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 09:49
  4. knocking / grinding noise
    By Graeme in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2011, 23:51
  5. brake grinding noise
    By li4m in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2010, 20:54
