Thread: Power Steering Pump ECU communication problem.
    Dec 2010
    Shropshire
    Default Power Steering Pump ECU communication problem.
    Hello All,
    The power steering on my 2004 Signum has stopped working. Took it to a local VX specialist who tried to read the errors using the Tech 2 system, but he said they are having problems communicating with the Power Steering pump ECU.
    They are going to check the wiring to the pump, but in a worst case, they think I could need a new Power Steering pump + ECU. Had some quotes of £600+ for the Pump and ECU which sounds like alot to me.
    I had a look on ebay and there are a load of power steering pumps like mine, but I struggle to find any with the ECU.
    Is the ECU part of the pump? And if I manage to source a pump and ECU, will they just plug and play on my car?
    Thanks in advance, Otis
    Dec 2010
    Shropshire
    Is there an ECU as part of the power steering pump?
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    i have the same problem with comunication to my pump the warning light is on pump still works perfect but the light will not go out and my op-com will not comunicate with it
    Same happened to mine on 03 January
    No warning, it just died and warning appeared
    Dealership took a guess, "Looks like the pump has failed, but it could also be the CIM"
    However they advised they have had this a few times
    On replacement the steering error then has to be cleared from the EMS as it remains even with a new pump
    Equally, they can clear the error which reactivates the pump, but there is no guarantee how long it will last
    Mine was reset and lasted all of 2 days, confirming it was the pump and not the CIM
    However £600 is way over the top
    The pump is about £500, but that includes a surcharge of £200, giving a net cost of about £300
    Labour is about 2 hours
    I was quoted £410
    My local garage was willing to complete this for £350, but they would then have to take the car to a dealership for the error to be cleared, as they had that issue on a previous replacement
    Mine is currently sitting awaiting a pump, the failed one has been removed
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Quote Originally Posted by otis_b View Post
    Hello All,
    Hi, Have you checked the electrical connections to the pump - mine went last year and I found it was the main connection plug onto the PS pump. Just cleaned it and ensured it was connected properly and it worked fine. There are two connecting plugs onto the pump - so worth cleaning / checking both.
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Quote Originally Posted by cossiejay View Post
    Have you tried disconnecting your battery for a couple of hours and then reconnecting it - this can sometimes clear a fault - make sure you have your radio code!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I have replaced one under the front wing and one behind the engine. They are easy to replace and can be got from Ebay.
    There used to be two types, one with oil level sensor, one without.
    Now the only new one you can get is the one without the sensor. If your car had the one with the sensor they have to program it out otherwise it will show a low oil warning all the time.
    You can get them on ebay for £125 or less. I would contact www.vauxcentre.co.uk and they will help you get a good used one for a reasonable amount of money.
    I cannot remember if they have to be programmed out/in to the car so check first, again vauxcentre will know. If they don't have to be programmed back in then its an easy job to fit.
  1. Power Steering Problem Pump/Sensor
    By Jimbob SXI in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2017, 09:34
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. 2004 vectra power steering pump problem
    By Yates0721 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th March 2012, 22:49
  4. Power Steering Pump/CIM... Help
    By popeye1983 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th February 2011, 20:01
vauxhall vectra no power steering
vectra c power steering pump programming
2010 zafira b power steering not working
vectra c power steering problem
vauxhall vectra power steering problems
power stearing pump repair on vectra c
vectra c no communication with steering assistance
vectra c no communication with power steering
can I drive vectra cwithout power steering
vectra c power steering pump replacement
opel vectra c power steering oe number location
insignia power steering ecu location
power steering no power at steering ecu
signum 1.9 cdti power steering problem
vauxhall vectra power steering failure
opel vectra c steering error remove
opel zafira a power steering pump ecu
vectra c power steering pulling
2004 opel signum power steering diagram
opel vectra c electrical diagram powersteering
vectra c pas pump coding
no communication power steering ecu
vectra cdti sri steering snatches
2003 vectra power steering pump programing
where is the Power steering pump on opel vectra gts
