Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Let me introduce myself with a list of problems!
    Nelson, Treharris
    Default Let me introduce myself with a list of problems!
    Firstly, as a new bod, a big hello to everyone here!
    Secondly.......help!!!
    I bought a 2003 2.2 Dti Signum a few days ago and it's giving me grief already :-(
    This is what I've noticed:
    Fuel consumption is about 33mpg
    Puffs of black smoke out the exhaust
    Tries to stall when pulling away
    Whilst driving I often get a juddering sensation (like a misfire)
    Whilst driving it will judder and then just cut out, but will restart okay
    Spanner comes up on the dash every few miles, goes into restricted power mode and then clears itself after about thirty seconds.
    Spent a few quid putting it on diagnostic and the following fault codes showed up:
    P0638 Throttle Control Circuit Positive Deviation
    P0703 Brake Switch Circuit Malfunction
    P0704 Clutch Switch Signal Incorrect
    P0380 Glow Device Circuit Low Voltage
    Anyone had these problems before? Any suggestions for things that I can do myself instead of paying labour charges would be gratefully received!
    Oh, btw - I also have a bulb failure warning on the dash, and the centre display tells me to check the rear brake light bulbs, but have replaced these even though all the correct lights are working, have also removed the light units and cleaned all the contacts to be extra sure?
    Jon
    Vehicle : Insignia sport tourer 2.0 CDTi
    Trim : /Elite
    Mileage : 34900
    Hi jon
    ok first one p0638 relates to your boost sensor , what is probably the case is that it has become covered with carbon deposit . easiest way to solve this is to remove the inlet manifold then remove thesensor and clean with carburettor cleaner , relatedto this you will probably find the egr valve , and the manifold itself will almot definnetly need a clean as well , all relatively straight forward just have a look in the how too section of the forum for guides
    p0703 no info at the moment
    p0704 no info at the moment
    p0380 relates to one or more of your glow plugs is faulty only cure for this to replace them have a look on ebay plenty on there going for a lot less than what the stealers will charge you.
    and still loving it
    West
    In addition to the above...
    Have a good look round all the Boost & vac pipe work for splits etc... it's sometimes easier to spot anything a miss if someone holds the revs around 2.5 k while you have a good look
    hth
    Trim : /Elite
    Mileage : 34900
    Jon in a addition to my earlier post can you post a pic of your engine bay with the engine cover off this way we can see what vacuum valve and t p s set up you have as these vary
    and still loving it
    Nelson, Treharris
    Quote Originally Posted by bobssignum View Post
    Thanks for all the advice so far- will get the engine cover off tomorrow and take some pics.
    Have ordered some Bosch glow plugs from ebay, so will get those in as soon as they arrive, and see if that cures one of the faults.
    Cheers!!
    Jon
    Regular Member Dazzy2006's Avatar
    Notts
    Quote Originally Posted by signum_jon View Post
    Cheers!!
    Jon
    Regarding the glowplugs - be VERY VERY careful when changing the glowplugs as they are prone to snapping - make sure you spray plusgas on them for a few days beforehand and the day you change them get the engine HOT and hopefully they will come out ok.
    I'm not trying to put you off but i've been quoted £700 to have a snapped glowplug removed and helicoiled
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    http://www.vectra-c.com/forum/showthread.php?t=70471
    Have a look at this thread its all the How to's and should help.
    Nelson, Treharris
    Quote Originally Posted by Dazzy2006 View Post
    Top Tip! Thanks as this is my first diesel and I would probably have attacked them in the same way as a normal spark plug.
    Jon
    Nelson, Treharris
    Cheers!!
    Jon
    Picture of engine as requested - EGR valve looks new? (assuming I'm looking at the right bit?)
    Jon
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Here's the others!.
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0704 Clutch Switch Input Circuit Malfunction
    just noticed your recent post so you may have a split boost or vacum hose, or if there's one or two small valves near the front r/h side near the radiator i believe they can be removed / parted & cleaned.
  1. New to introduce
    By fksignum in forum Introduce yourself.
    Last Post: 20th April 2012, 15:57
  2. recall list/ common problems
    By Tank988 in forum The 'Off Topic' room
    Last Post: 18th July 2011, 14:51
  3. New Vectra! Couple of little problems, Fuse list anyone?
    By robert31 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2011, 23:37
  4. hello. let me introduce myself!
    By v6blue in forum Introduce yourself.
    Last Post: 20th December 2008, 20:28
  5. May I introduce myself and my car please?
    By Sparkyvxr in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2005, 22:28
