Thread: Usual EGR Probs - however are they trying to shaft me??!!!
    STOCKPORT
    Default Usual EGR Probs - however are they trying to shaft me??!!!
    Hi.
    Iv'e developed a problem with my car and found this thread -
    http://www.vectra-c.com/forum/showthread.php?t=122008
    This is exactly the same prob I have. Been to the garage today and they've quoted me this -
    new intake manifold - 203.00
    EGR Valve - 113.00
    EGR Gasket - 2.89
    Manifold Gasket - 13.30
    Throttle body gasket - 2.07
    Cambelt kit - 114.00
    Water pump - 56.50
    Type D Coolant - 30.00
    RTV Sealant - 6.00
    Glow Plugs (new set we're fitted less than 9 months ago?) - 52.00
    Labour - 300.00
    Total incl VAT 1071.31!!!!!!!
    However they've also thrown in Possible ACC unit - 165.00 for good luck!!
    Does this sound right to you or are they trying to pull my pants down???
    Thanks.
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Quote Originally Posted by Paul H. View Post
    Hi.
    EGR Valve - 113.00
    EGR Gasket - 2.89
    Water pump - 56.50
    RTV Sealant - 6.00
    Labour - 300.00
    Thanks.
    tbh I think its a good price - vauxhall will want more than that for the inlet alone.............and once all thats been done you shouldn't have any other probs................£300 for labour for all that is very good IMO
    STOCKPORT
    ok, so it's a good price for all of that work but do i really need all of this work???
    Jun 2009
    bradford
    i would guess the swirl bar is off on the inlet?
    the egr is not cleanable and is ****ed
    the belts need to be done if inlet removed-water pump is a good idea at same time,
    glow plugs-is it sruggling starting?
    stockport
    Exclamation
    Timing belt DOES NOT need to be replaced,(unless it is worn etc),as the removal of the inlet manifold can be achieved by locking the pulley in place using a cam case cover bolt.Ask Wizard or John robertson,they did the job recently and posted a superb "How2" about it FELIXX.
    Jun 2009
    bradford
    i stand corrected
    STOCKPORT
    Well well well, ...... I was driving back from the garage today (well trying to) and whilst going up a hill that car completely broke down.
    Called the AA who came out. The AA bloke 'blanked' the valve of so it just takes in fresh air and the car drives absolutely fine. I told him about the diagnostic check the garage did and the price and he laughed his ******** off. He reckons the EGR valve needs replacing that is all. He reckons the garage are tying to do me over as I mentioned to them that I have a warranty. He's also heard of other people having probs with the said garage.
    Taking it for a second opinion on monday to another garage recommended to me. I really hope this is all that needs to be done. I can't afford a massive bill.
    Regular Member Dazzy2006's Avatar
    Notts
    If you have a warranty that covers that lot wouldn't it be worth getting it done so you know those parts wont fail in the future - at the end of the day its a cdti 150
    STOCKPORT
    if only. I bought the car through CarCraft (go on, have a laugh on me!!)
    The warranty is through NAC. They only cover up to £300.00!!!
  1. not your usual HID question!
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2011, 23:27
  2. the usual q's
    By jays_225 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 17:49
  3. Not your usual DMF thread
    By barney490 in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:58
  4. are these usual problems?
    By tonypc1 in forum Engine & Drivetrain
    Last Post: 11th July 2007, 19:49
  5. Not the usual mpg
    By simon5800 in forum General Chat
    Last Post: 20th June 2007, 16:21
