Thread: front bumper
    kirriemuir
    Default front bumper
    hi my front bumper is out of line with the wing it was resprayed by the dealer just before i got it. just got a haynes manual and looked at the how2. now the manual says you take out the top screw a push in the sliding bumper bracket to remove do you think if i take out the top screw and push the bracket in this would align top top piece? or will i have to remove it further?
    kirriemuir
    missed out its a facelift 2009
    Regular Member gibbon7000's Avatar
    lincs
    Yep, undo the top torx screw in the wheel arche, pull out and reset, it does sometimes need a good bit of force required to clip it in. There is a possibility that the gargae have broke the clips when they did the respray. hth
    kirriemuir
    good i,ll give it a try if its a broken clip i,ll take it back. 7 months its annoying me now
    kirriemuir
    sorted the bit next to the bumper still a little bit out on the headlight joint
    lincs
    Do you mean there is a very slight gap as the bumper goes around under the headlight?
    kirriemuir
    yes and no the join between the front part of the wing beside the underside of the headlamp
    lincs
    Any chance you can post a pic up?
  1. Signum front bumper (Vectra c pre-facelift sri bumper) rubber skirt
    By 2.2 DTI SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2012, 20:23
  2. Rear Bumper Repair GSi, Front Bumper soon!
    By Vectra_C_Chris in forum Quick Photo Album
    Last Post: 7th June 2011, 12:32
  3. Replies: 8
    Last Post: 11th March 2008, 19:28
