Results 1 to 3 of 3
Thread: whining egr
    belfast
    Default whining egr
    hi people, i posted in the general forum yesterday about my whining egr valve, i didnt have much response so i'll try here to see if i can get a result. i have a 04 vectra 2.2dti estate. i have cleaned the egr valve and its sliding up and down like a pole dancer on her pole. i put a little cooper grease on also, so everything is good. unfortunately its still going into limp mode and stopping. when the egr is disconnected, i can drive all day, every day. when connected, and the car has went into limp mode, i have found that the egr valve is making a whining noise, once the whining stops the car will start again. has anyone else experienced this, is the egr valve knackered???
    Vehicle : Insignia sport tourer 2.0 CDTi
    Trim : /Elite
    Mileage : 34900
    Never heard of this happening , have you had your fault codes read .
    just wondering if its your solenoid that is whining ather than your egr
    and still loving it
    belfast
    fault codes were saying throttle body sensor, which has now been replaced. i have checked all pipes, hoses, connections for cracks etc. i have removed the throttle body and egr and gave it a good as new clean. just to reiterate, when the egr is connected, the car will drive, then when the spanner light comes on, it cuts out. when i open the bonnet u can hear the whining, which is coming from the egr, as soon as i disconnect, the whining stops. the car will not start when connected and the whining is present. just to be clear, if the egr vale is connected and there is no whining, then the car will start and drive.
  1. HELP! whining from the front
    By Ann in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2013, 16:32
  2. whining noise
    By Swedge in forum Engine & Drivetrain
    Last Post: 21st November 2012, 23:23
  3. whining egr valve
    By donut in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 20:29
  4. whining noise (HELP)!!!!
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 20th March 2009, 09:03
  5. Whining Noise
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2008, 09:08
