Thread: vectra keys
    Regular Member hamish123's Avatar
    norfolk
    Default vectra keys
    Hi goy my vectra cdti sri 120 yesrerday and it just what i thuoght it would be .
    But i only got the one key do you have to get them from vx dealer or does anyone else do them as presume they have a chip /transponder in them that requires coding to the car
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    You might be able to get a new key and transponder from Ebay but it would still need to be coded to the car. you CAN NOT buy a second hand key and have it linked to your car. It can only be done once.
    Regular Member i5aces's Avatar
    andover
    i have been looking into the same thing so was wandering if someone could shed some light on it as it would help me and the OP.
    there are two parts to a key
    1 the bit that unlocks the doors
    2 a transponder that disables the ibobileiser (shocking spelling)
    from what i have read the bit that unlocks the doors can be reprogramed but the transponder cannot,
    so in theory you could buy a second hand key replace the blade and transponder and have it all programmed and work.
    is this correct or have i misread
    also when i look in my key i have a circuit board bit not a chip (there is a space for a chip but its not there) however if i try start the car without the button part of the key fitted i get a car and padlock displayed
    is the transponder built into the circuit board (difficult to replace)
    i dont mean to hijack the thread but like i say any help could help both of us
    Sep 2009
    middlesbrough
    Im not sure on the above but a local locksmith will do you a spare key for about £100-£120
    andover
    Quote Originally Posted by durham4416 View Post
    the only reason i ask is because if what i wrote is correct i think if you have or know someone with the software to program the key you could get a replacement all don for about £30 to £40 i saw a website you can buy the transponder chips for about £5 and blades for about the same
    norfolk
    hi thanks for info am going to call my vx dealer and see how much for the key and coding
    andover
    Quote Originally Posted by hamish123 View Post
    I was quoted £120 I think
    PRESTON
    £120 about right at the dealers, but £50 of that is what they charge for the five to ten mins it takes them to code the chip to the car.
    Regular Member Innes's Avatar
    Plymouth
    Hi Guys,
    the old Vauxhall keys (before the Vec-C) were two stage programming. You'd code a new blank transponder (slides out of the horse shoe) and then code the central locking built into the key...
    HOWEVER....
    The Vectra-C is an all-in-one unit that can only be coded once. The central locking and imoboliser are as one. You cant programme any part of a second hand key for a Vectra-C.
    I advised a member a while back about how to go about it on this thread. Have a read and see if you fancy having a go.
    http://www.vectra-c.com/forum/showthread.php?t=110946
    13 Post(s)
    There is also another resync procedure - which is mentioned in the handbook.
  1. Is it possible to steal a Vectra-C without keys?
    Last Post: 12th July 2012, 18:58
  2. My Vectra keys
    By mtqn in forum Bodywork & Interior
    Last Post: 27th June 2012, 23:52
  3. Vectra C Fobs/Keys
    By Tam80 in forum Engine & Drivetrain
    Last Post: 14th September 2010, 21:23
  4. Vectra C Flip Keys Watch what you buy
    By 3.2wales in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2009, 07:19
  5. Vectra keys.......
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2009, 08:42
