Results 1 to 10 of 14
Thread: Few problems
    Shropshire
    Default Few problems
    Can anyone help me?
    Tried to put extra boot lights in today, using LED strips off Ebay. Tested them on the boot light connector, worked fine. Cut them to length, then tested again. Still fine. Used some snaplock connectors to speaker wire, tested on the plug, don't work. Took the snap locks off, and tried just the leds, they don't work now. Is there something I've done wrong?
    Also, I removed the head unit, as it wasn't sitting flush after fitting an IO Play. Didn't disconnect any wires, none fell out, but now I have no sound through radio or cd player, but I still do through the IO Play which is coming out of the car speakers. Is it a HU out and fiddle with the wires again job? Already spent half an hour doing this, and got nowhere other than in a temper !
    Finally, I put a wiring loom in for the auto dim mirror, rear light etc ages ago. When putting the roof liner back, it left a big gap by the rear window. So, I decided to try and put it right today. I pulled the slack ribboncable further into the boot, banged on the roof liner and everything is now sitting pretty. But, the map lights don't work, and the interior light only comes on when ignition switched off/door opens. When driving, I can't swithch it on. I'm guessing roof liner down again? Really don't know where to look though, as the plugs in properly, so don't know why it's stopped working.
    Typical for me really, tidy some bits up, and create more problems!
    Jul 2009
    The Rift, Cardiff
    did you try closing the boot and locking the car then open boot again to see if it worked as the boot light turns its self off after a while of the boot being open?
    Shropshire
    Yep I'd taken the bulb out anyway, and as soon as I put it back in it worked, so there was power going through it all the time. I think. Should have worked. Will give it another go tomorrow, as I'm determined not to let it beat me - if I can't wire in a couple of LED strips might aswell not even think about the other things!
    Shropshire
    Got the interior lights all working, and cleared the safeguard message that appeared last night - plug was loose in the electric box in the boot
    Boot lights still no good though
    And still no audio from radio unit
    Any ideas?
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    I know its silly and you've probably checked but are the LED lights 12v per strip? And have you taken power from the existing boot light?
    When I did my boot LED's I had no problems at all lol
    Shropshire
    Thanks for rubbing it in.....
    Well, I bought them as 12v, and they lit when connected directly to the boot light, but not after the speaker wire was added, even when that was removed and direct again. Only cost a few quid, so may look at getting some more, and maybe some better wire.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Know when I did mine I ended up blowing a fuse on the passenger side dash board (cant remember which one it was though)
    Hope you get it sorted
    Sep 2009
    Glasgow
    red fuse number 20 i think, probably wrong
    Year : 55
    Mileage : 92,000
    Yep it was a red fuse but was supposed to be blue 15A (in my case )
    Fuse 20 in passenger fuse box relates to "Yaw Sensor" so doubt it was that.
    I think it was Fuse 12 "Battery Control Unit" but don't quote me on that
    Shropshire
    Cheers, I'll have a look tomorrow. Would that not stop the normal boot light working though?
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 12th November 2019, 09:21
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
