Thread: whining egr valve
    belfast
    Default whining egr valve
    hi everyone, as the title says, my egr valve whines??? the car will drive all day everyday with the egr valve disconnected, but obviously will be in limp mode. i have cleaned the throttle body and egr and when it is reconnected the car will go into limp mode and stop. i have now noticed that the egr valve is whining. as soon as it is disconnected the whining stops. if i reconnect and the whining has stopped the car will start, and so on......whining starts car stops, whining stops, car starts..???? is there anything can be done to rectify this or is a new one on the cards???
    MY CAR IS A 04 2.2DTI ESTATE.
    Liverpool
    do you get EML?
    belfast
    spanner light comes on.
    Liverpool
    get a code reader and find fault code, it could be something else causing it, if not it might be a new EGR :S
    belfast
    have done that already and it said throttle body sensor which has been replaced. would anything else cause the egr to go into some sort of failure and cause it to whine though?
    Liverpool
    if it is still throwing up the code, then it may have something to do with it still
    has the egr got full travel, all the way open/closed?
    belfast
    egr valve working great mechanically, its just been cleaned and i put a little cooper grease on the piston and it slides very very easily. i only cleaned it and the whining was almost immediate, but is intermittent
    belfast
    anyone else experienced this before??
  1. HELP! whining from the front
    By Ann in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2013, 16:32
  2. whining noise
    By Swedge in forum Engine & Drivetrain
    Last Post: 21st November 2012, 23:23
  3. whining egr
    By donut in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2011, 11:56
  4. whining noise (HELP)!!!!
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 20th March 2009, 09:03
  5. Whining Brakes.
    By Russ3.2GSI in forum Engine & Drivetrain
    Last Post: 10th April 2006, 08:55
whinnin from egr valve
Erg valve wineing noise
whine from egr valve
egr valve whining
