Thread: Clay Bar - Info
    Durham
    Default Clay Bar - Info
    Hey all.
    I just recieved my Clay Bar from the courier. I opted for the Bilt Hamber "soft" Clay, its the 200g size.
    I have watched a lot of videos of 'how to' but im still a little unsure on a few things.
    Surely I dont use the whole of this clay bar? From what I have seen I can split this up into 4-5 pieces? - Some use small, some use large bits - Can you advise?
    Also, when its been clayed, and the surface is all wet again after the job is finished, what do i do? I have seen some people just use a leather shammy to wipe it over? - is this right?
    Do I need to polish it after I have used a clay bar? - I use Autoglym normally.
    Many thanks
    Regular Member no1golfer's Avatar
    Jul 2009
    newcastle upon tyne
    Yes,you can use the clay either way,myself use aprox a squashball size piece at a time and remember if you drop it on the floor bin it.
    After claying wash again and the rest depends on the paint finish/quality on the car.
    If there are swirls or scratches you would need to do some corective work(polish etc) then wax or sealant to protect the work you've just done.
    If the paint is ok skip the polish and just wax it.hth
    Liverpool
    if i am going over car and its going to be an all day affair, i will first jet wash and hand wash first, then use about 30g of clay flattened into a small disk which i keep folding over as i work around car
    then i will hand wash for a 2nd time, then either meguiars scratchx it then wax/seal or just wax it
    then a few coats of detailing spray wax to get a deeper shine
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Cut the bar into 4 pieces and use one piece. One piece will do about 2 to 3 cars. If you drop the piece on the floor throw it in the bin, do not attempt to use it on the car, this is the reason you cut it into 4 pieces and dont use the whole bar.
    After you've clayed the car I would recommend you wash the car as per normal. Once washed, dry, and then its better to go through your normal polishing routine SRP followed by EPG or HD Wax etc.
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. Clay day!
    By Derek Mc in forum Detailing and Car Care Discussion
    Last Post: 16th April 2011, 22:47
  3. How often do you clay your car!?
    By paul_sri150 in forum Detailing and Car Care Discussion
    Last Post: 13th February 2011, 18:50
  4. Gonna take you to a clay bar, clay bar CLAY BAR!!!
    By peppered in forum Detailing and Car Care Discussion
    Last Post: 7th September 2009, 21:11
  5. clay b4 and after
    By sristeven1 in forum Detailing and Car Care Discussion
    Last Post: 23rd May 2009, 23:05
