Thread: Central Locking Microswitch
    Ayrshire
    Default Central Locking Microswitch
    Hi what part has the central locking microswitch, O/S/F. 2003 Veccy
    I have tried pushing the latch of the lock in twice but that light still stays on as if the door was open. So no point trying the to move the stricker plate, I have looked over the net and see it uses a door lock motor and solenoid, but what part contains the microswitch as it is built into the lock itself.
    Jul 2009
    The Rift, Cardiff
    Have you tried reseating the door loom plug? Sorry, cant help with the microswitch.
    13 Post(s)
    I thought the microswitch was in the door stay assembly, not the latch. Same place as the interior light switch - might even be the same switch?
    Ayrshire
    Cheers ChrisBilly that has worked , took off the door loom there was small amounts of moisture in there, gave it a blast to get the water out and thats it, hopefully it will be ok. Whats the best way of stopping any more water from getting in, there seems to be a orange ring round about it which seems in good condition, but yet the water still got in?
    Ayrshire
    right an update, the door loom fix lasted two days. I thought i had found the fault with some moisture being in the plug, but was wrong as it now and again gave me a door open light. The only way it would let me lock the doors or stop the car thinking the door was open was to reset the door loom plug, after that it was fine for a short while.
    I finally found the fault yesterday and it has nothing to do with the door switch, its the window motor don't know why the only thing that gave me a hint was that when the car thought my door was open the window would only work when i kept my finger on the button, usualy you can hold the button down for a few seconds and it would do it automatically. I took the door card off pulled the window motor plug out and the door switch works fine, triple checked it to make sure by plugging it back in and everytime the door light comes back on.
    So just thought id give you all update and has anyone else had this before?
    Nov 2009
    Lancashire
    I'm having a similar problem at the moment too.
    My O/S/R door is showing as open on the little dash display, but it isn't.
    The problem though is that the interior lights won't go out. I can't turn them off so I've had to take the bulbs out.
    The weird thing though is that the rear-view mirror doesn't seem to auto-dim either now.
    These cars are too damn clever for their own good!
    Is a new lock mechanism required to fix this?
    Has anyone else had this fault?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    yes new lock is needed.. ive changed mine due to the same problem.. (also a how2 for that)
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    13 Post(s)
    Vehicle : Opel Vectra C
    Trim : Cosmo OPC Line
    Quote Originally Posted by fantasyjb1 View Post
    After you have unplugged the door loom you have to reprogram the auto windows by keep pressing th up button for a few seconds after the window have reach upper position.
    Think you have to change the lock to solve this problem.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
  1. central locking key fob
    By Mickyboy in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2012, 23:50
  2. Central locking... just had new CIM...
    By kenp in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2011, 14:33
  3. Central locking
    By stevie16v in forum Bodywork & Interior
    Last Post: 21st March 2011, 18:56
  4. Central locking
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2010, 12:14
  5. central locking help !!!!!!!
    By VECKSZ in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2009, 17:37
where is the central locking sensor for vectra c
vauxhall central locking motor microswitch repair
vectra c door light switch www.vectra-c.com
vectra door microswitch
