Thread: Squeeky clutch Pedal
    in a house
    Default Squeeky clutch Pedal
    Its dooin me nut in, the slightest pressure applied to the pedal and it groans, not loud just its like there and stops as soon as its depressed to change gear. its just like the first 2" of travel. Is there a simple solution or am i looking at new parts???
    To be fair i havent looked under the console yet or sprayed anything, just wondering if anyone else has had this issue.
    West
    VX have been famous for it for years lol... a bit of spray grease down under the dash on the linkage etc will sort it out for a while
    Sep 2010
    Mine was recalled for a new spring fitment - check with VX
    Regular Member rob fletcher's Avatar
    Sep 2010
    aylesbury
    I have the same problem...... It drives me mad once i start listerning for it
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Will try the grease method. Got the same problem. Will reply once attempted.
    Holden never offered a recall.
    Sep 2010
    aylesbury
    I finally cured it!!! it's the spring rubbing against the plastic retainer, bit of grease and rotate the spring with you fingers, all quiet
    Jul 2009
    Wiltshire
    When I bought my Mk3 Cav I pushed the clutch pedal, and it creaked. The salesman was quick to tell me that he'd get it sorted. I replied that if he stopped the pedal squeaking, I'd walk away from the car, cause I'd be worried that there was something wrong with it.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch pedal
    By BigWilko in forum Engine & Drivetrain
    Last Post: 9th January 2011, 08:38
  3. clutch pedal
    By Tam80 in forum Engine & Drivetrain
    Last Post: 2nd September 2010, 19:41
  4. Clutch Pedal!!
    By andd306 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 21:48
  5. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
