Thread: Brake Warning Light
    Regular Member brotherkennyh's Avatar
    Swadlincote
    Default Brake Warning Light
    This morning I was out in the veccy and as I pulled up at home the brake pad wear light came up.
    I assumed I just needed to change the brake pads, but when I got back in the car half an hour later to go to work there was no brake pad wear light and it did not come up during my journey.
    I have never worn my brake pads enough for the light to come up before, having always changed them early when servicing.
    Is this behaviour normal or if the brakes are really worn should the light still be on? Or is there possibly another probelm, in the circuit perhaps?
    Kenny
    Regular Member hutch's Avatar
    Sep 2010
    TELFORD
    probably just a blip mate...it happens sometimes. if it kepps coming on thats the time to check.
    Swadlincote
    Thanks.
    I will just keep an eye out for it again then and keep my fingers crossed lol.
    Normally it comes on when the sensor has been worn through, breaking the contact
    However, it is possible the sensor was not responding so the ECU assumed it had failed
    This could have been caused by the wire being broken within the sensor (due to water freezing and then thawing within it)
    A long time ago mine came on
    A visual inspection confirmed the front pads needed replacing
    The dealership then ordered them, wrong parts came in, a further two weeks passed
    On the last day the warning stopped!
    I pointed this out, and they found the sensor had melted and fused
    Swadlincote
    In that case I might take a look myself anyway, just to be on the safe side.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 07:26
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake warning light
    By scar_vectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2007, 12:48
