Results 1 to 5 of 5
Thread: 1.9 cdti brakes
    southampton
    Angry 1.9 cdti brakes
    Hi Guys,
    The brakes on my 1.9 have stuck on, done the usual haynes checks and it seems ok vac and such. Does anyone know of any common issues with these brakes or have any suggestions or pointers as to where the problem maybe?
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Front or rear?
    Could be a seized caliper or sticking pad.
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    just had the garage pump my pistons (oh er missus) all the way out and clean them up then wind them back in. That sorted them right out and passed the MOT. not bad for £30! Can't be too careful with brakes!
    southampton
    all sorted now, night before heard a loud bang could not see any damage but a core spring had snapped while it was parked which had locked the brakes on. found a local mobile mechanic just replaced it for £90 good as new. i found the bottom coil of the spring on the driveway after car was collected
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Quote Originally Posted by homerj View Post
    Hi, What do you mean by a 'core spring' - I had a problem with the handbrake return spring on the rear caliper that wasn't releasing the handbrake properly and causing it to drag - I managed to get a stronger spring that cured it but later changed both calipers with GM ones.
  1. 19 cdti sri brakes
    By kenny22 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 23:01
  2. cdti sri brakes
    By rob warrington in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2010, 14:11
  3. brakes for CDTi
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2007, 13:16
  4. 1.9 CDTi brakes
    By AJA in forum Suspension, Wheels & Brakes
    Last Post: 12th June 2006, 11:15
