Thread: Clearing the EML light
    Regular Member Gortreck's Avatar
    Sep 2009
    Newcastle Upon Tyne
    Default Clearing the EML light
    Hi folks
    I have had my tensioner and auxillery belt changed by the garage but they couldnt clear the fault code as the comms port doesnt have a live to it for some reason and all the fuses are ok. Can I clear the code without a code reader?
    Tony
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    the code should clear itself after a certain amount of restarts without the fault, if the fault still exists it will not go away though. what fault code was it?
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Exactly what Caveman said. It should clear itself after a while unless the fault is still there. If you unplug the battery for 10 minutes then reconnect that'll clear it but you'll need your radio code with being a half CANbus car.
    If the fault comes back then take it back to the garage. The chances are there's nothing wrong with your diagnostic plug either, it's just the 2.0 DTi and 2.2 DTi are very, very picky on what they'll talk to. Tech2 or Vaux/OP Com would probably work perfectly fine.
    Chelmsford
    I always thought that the "unplug the battery" thing was a myth which started with the old Cavaliers and hasn't worked for years... It never did for me anyway.
    It's right what the guys have said though, a certain number of engine runs without fault will kill the EML anyway. Just start and stop the engine about 10 times and it should disappear
    Sep 2009
    Newcastle Upon Tyne
    Thanks for the replies guys,
    Re the plug though, my mechanic actually tested the live into the socket and it wasnt "live" i think was what he meant. I guess the only surefire way to test it is if there is anyone near me in newcastle with one of the above testers would be willing to check it for me?
    Tony
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Light clears after 10 days, if fault is not present anymore.
    13 Post(s)
    Mine took 28 days to disappear.
  1. Clearing Emissons light
    By ianh in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 21:23
  2. clearing error codes
    By shadow.warrior in forum Engine & Drivetrain
    Last Post: 26th July 2010, 13:35
  3. Help with EGR fault clearing please?
    By johnny_M in forum Engine & Drivetrain
    Last Post: 27th May 2010, 22:14
  4. Clearing nav on a CD70
    By mel in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2007, 23:30
  5. Clearing It Up
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2006, 18:32
