how do i remove the lip spoiler off the back of my tailgate? i plan on putting it back on so dont want to damage anything
You will need to remove the interior trim panel from the tailgate first off, as there is x2 6mm studs "10mm spanner size" inside the tailgate. As it is also glued with double back foam tape to the tailgate you will need to ease your way through this with maybe a "plastic body filler spreader" carefully. Try not to pull the spoiler until you have released most of it as it will bend/twist and not go back on again......
i take it you can get this double sided tape from vauxhall? what is it for? how easy is it to get off would the wives matalan card get it off ok?
thanks!!
