Thread: Vectra C Z18XER Gearbox Probelms!
    Jul 2009
    Northampton
    Default Vectra C Z18XER Gearbox Probelms!
    Hi There,
    Been on the forum for a while but never had an issue to post up until now!
    My Vectra is at 106k on the clock and only now am I just starting to get problems. At first there was a squeek when letting the clutch up in 1st but only if I had to get out quickly i.e. bad crossing.
    For a while I could tolerate this and just went easy on it which worked! However then over the past few weeks it started to make a whine noise in 4th and 5th gear over 2,500rpm and more noticable in overrun.
    This stopped and now I am left with a drill high speed noise in 1st and 2nd! I think my gear box is on its way out. It even makes a slight whir when its out of gear at low speed. I am changing the thermostat this weekend as that has failed.
    I dont mind getting another box 2nd hand or something but is there anything I can do to make it last like another month? I believe it is an F17 box but can not be sure also.
    Please help any thoughts?
    Cheers,
    Chris
    scotland
    sounds like the diff it it makes the noise on over run and also coasting , mine is the same been like that since last feb will get a new box soon , oh an it is F17 but think you get a close ratio version of this box ?
    Jul 2009
    Northampton
    Well just coming back from lunch and in 2nd it kept crunching whilst in gear both accelerating and in overrun. Anyone know of a cheap place to get a box fitted in Northampton!? I dont think it will last much longer.
    Jul 2009
    Northampton
    Just took the reverse light switch off and it seems the box is low on oil. What oil can I get to add to the current oil it has in it? And having a search on google what is the F17+ box?
    Jul 2009
    Northampton
    BUMP!!!
    Come on people does no one have access to VX details for my box I need to know what my final drive is or full code as the boys in the garage cant tell me yet and I need to buy a box asap!!
    Chris
    Oct 2007
    Shropshire
    This is massive Dejavu for me! I have had three gearboxes in mine. The diffs are literally made of chocolate!! I have put a Quaife LSD in beacuase they are stronger!
    I don't know the final drive but get one from a vectra. If you get one for a corsa or astra it is wrong. Any 1.8 vectra c is fine, do not go for vectra b as the changing mechanisium is different. There are tons around!!!!
    Also mine has only done 57k so 123k sound good to me!
    Oct 2007
    Shropshire
    Code is on the side. Take the passenger wheel of and look through the wheel arch at the end of the gearbox. You will need to wipe it clean!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Jul 2009
    Northampton
    Lifesavers!! So far so good I have been quoted final drive of 4.19 which would tally in for gazza's info how'd you find that page I have no idea but way cool.
    I will just source one from another Vec C then! Would I get away with a 3.98 final drive or should I try to get one for 4.19?
    I know the diff's arnt up to much I put it down to the VVT having 140bhp instead of the standard 1.8 engine is this correct?
    Also I have been looking around for something that can take my beatings daily lol!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    [QUOTE=demoni;1434257]Lifesavers!! So far so good I have been quoted final drive of 4.19 which would tally in for gazza's info how'd you find that page I have no idea but way cool.QUOTE]
    Some other member who loves rambling on about gear ratios found that one. I can't take credit.
    Glad it has been of some use.
    Gazza4
  1. What Oil Vectra SRi 1.8 Z18XER 2007 Model
    By shammon in forum Engine & Drivetrain
    Last Post: 11th May 2012, 01:41
  2. Vectra Z18XER Poor Running
    By mxspyder in forum Engine & Drivetrain
    Last Post: 12th March 2012, 11:13
  3. For Sale: Vectra/Signum 3 Piece clutch kit (Genuine) to fit Z16XEP/Z18XER
    By lee gsi in forum Parts for sale
    Last Post: 29th December 2011, 15:36
  4. Probelms with car so far..
    By stevea1234 in forum Insignia car chat
    Last Post: 24th November 2009, 09:06
z18xer gearbox
z18xer what gearboxz18xer squeekastra z18xer gearbox
