Results 1 to 10 of 11
Thread: chirping noise
    Aug 2010
    herts
    Question chirping noise
    started the car this morning and it started to make this chirping noise also when moving the steering wheel side to side lasted for 20 seconds then no noise??? any ideas its had a new aux belt and tensioner also new battery.
    Jul 2010
    Warrington / Liverpool
    Could it be the alternator on its way out?
    Aug 2010
    herts
    anyway to test it.
    Jul 2010
    You could measure the voltage at the battery terminals with the engine running, usually any extra strain on it and the voltage will be low...
    What was the aux belt replaced with, just reading through some past threads apparently cheap belts sometimes aren't as good as Vx ones...
    Sep 2009
    middlesbrough
    do u still get noises through the radio with a knackered alternator?
    Aug 2010
    herts
    it was done at vauxhall so the parts should ok
    Jul 2010
    Hmm not sure... I think it would have to be quite bad for the output to drop below 12V but I'm no expert.
    Alot of people seem to say cleaning the pulleys; aircon and tensioner ect. with spirits helps. Apperently when they get crudded up they add more strain on everything turning and the belts slip a bit.
    Aug 2010
    herts
    ok mate ill start by checking the alternator first then the rest. thanks!!
    Jul 2010
    No worries boss, not my ideas anyway i'm just robbing everyone elses lol.
    Hope you get it sorted mate
    North East
    Ive got the same chirping noise on my 2.2 petrol SRI, I've had a look but I am befuddled as how to remove the aux belt to clean up. Do I need to remove it from the bottom???
    Thanks in advance.
    Lee
  1. Help with Chirping Noise
    By rossc1976 in forum Engine & Drivetrain
    Last Post: 13th October 2012, 16:36
  2. chirping noise from engine bay
    By Billythebubble in forum Engine & Drivetrain
    Last Post: 15th December 2011, 21:23
  3. Chirping noise on cdti
    By ChristopheCDTI in forum Engine & Drivetrain
    Last Post: 16th July 2011, 21:48
  4. Chirping noise CDTI please help
    By ONEMINUTESILENCE in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2011, 19:47
  5. Chirping noise when turning left
    By MrLOL in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:50
