Needing some info please....
2002 veccy 2.2dti dual mass flywheel broken or not?
I have removed gbox ,pressure plate and clutch plate leaving just the dmf in place. Is there any way i can confirm that the dmf is broken or not? There is no obvious sign of any damage and it will rotate on the flywheel slightly by approx 10 degrees then return to position. Any ideas anybody before i shell out the cost for full replacement
Thanks gents
