Results 1 to 10 of 15
Thread: Gearbox fluid change
    Regular Member Knuckle's Avatar
    South
    Default Gearbox fluid change
    Hi guys,
    Can anyone confirm how many litres of oil i need to do a gearbox oil change on a 2006 55 plate 2.2i direct with 6 speed box?
    I was just going to get the oil from VX as they wanted £8 a litre which is fairly priced and would imagine is best for the car. (Unless others recommend another fluid?)
    Do you need to buy any new washers etc? Think ill get it done elsewhere unless VX dont want an unreasonable amount (spoke to a complete retard on the phone that asked me if i wanted to complete the entire 'pipe'...thought it best not to ask them lol)
    Reason for change is that 2nd and 3rd are a bit notchy whilst the other gears are silky smooth
    Regular Member i5aces's Avatar
    andover
    i would like to know the answer to this to mine is a bit notchy between 1st and 2nd i have the vectra 3.0 6 speed box (i assume there both f40)
    Regular Member PORKBALLS29's Avatar
    Epping
    2.4 litres you will need, I used Castrol smx-s and then also some molislip as well. Very easy job to do - took me about 45 mins and that is including taking battery box out and putting it back in - you wont need to do that. Also there is a how 2 in the how2 section .
    Regular Member Jezzy's Avatar
    S.E
    2.4 litres IF you have the F40, if you have some other box then it's a different amount.
    S.E
    Quote Originally Posted by PORKBALLS29 View Post
    Have you noticed an improvement, Howard?
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    If you look at this site http://www.opel-infos.de/getriebe/f40.html you will se that the F40 gearbox should have 2,2 liter oil. I have hear the oil amount is reduce from what it was in the begining.
    Regular Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    That site all in German
    Regular Member david.aka.judas's Avatar
    Suffolk
    Quote Originally Posted by zafira View Post
    mine is a f35 box and it states 1.8 litres, I though it was 1.9.... any ideas?
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by david.aka.judas View Post
    Unless someone has an accurate answer it might be worth getting in touch with VX and finding out or measuring how much comes out when you drain and put the same amount back in. My F32 box took 1.9 litres. Used the Castrol stuff recommended in here with a tube of Molyslip. What a difference, feels much smoother now.
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    the correct amount is 3.2 litres but vx introduced a field remedy if the gearbox is notchy between 1st and 2nd gear they said to reduce the amount to 2.4 litres which i did to mine but it hasnt really helped but then its only notchy 1st thing in the morning 1st couple of gear changes and then fine after
  1. Auto Gearbox Fluid Change
    By Homer in forum Engine & Drivetrain
    Last Post: 15th November 2012, 10:50
  2. Gearbox fluid question
    By Gubmint Agent in forum Engine & Drivetrain
    Last Post: 27th November 2011, 20:02
  3. F35 Gearbox Fluid Change
    By si_hoss in forum Engine & Drivetrain
    Last Post: 10th September 2011, 00:03
  4. gearbox fluid leaking ?
    By pro auto valet in forum Engine & Drivetrain
    Last Post: 25th October 2010, 19:59
  5. Gearbox/clutch/brake fluid change-TOMORROW!!
    By nikroc in forum Engine & Drivetrain
    Last Post: 23rd February 2010, 22:49
