Results 1 to 2 of 2
Thread: No clutch pedale
    Belfat (NI)
    confused No clutch pedale
    Have a vectra c 2005. Changed the fly whhel, clutch, and master cylinder, and has no pedale. Has been bleed 7 times no leeks, Pedale there for a bit then goes, sticks half way or to the floor? Have even pressure bleed.Please help
    Regular Member DaveW555's Avatar
    Cannock
    do you mean you changed the slave cylinder in the bell housing? if so then sounds like you need a master cylinder as well (the one on the back of the pedal), theyre only about 80 quid for a genuine one and a doddle to fit, then its just bleed it up and should be problem solved.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
