Thread: help please car running bad spark plugs
    Dec 2010
    wiltshire
    Default help please car running bad spark plugs
    Hi can some one please help i have just changed the spark plugs on my v6 3.2l vectra c gsi and it is now running really bad, loads of smoke on initial start up no power and engine warning light on dash when acelerator pressed.
    The car was fine before new plugs fitted
    11 Post(s)
    Try refitting the old plugs and see if the fault is still present.
    I take it you've put the coil packs back on properly?
    Also, did you use the correct plugs? GM/Vauxhall ones are as good as any and will be the correct ones. Also cheap as chips.
    Dec 2010
    wiltshire
    Thanks for the advice try it today. Ref double post my bad computer is a bit slow so wasnt sure if posted the first time.
    Dec 2010
    wiltshire
    Yeah fixed it was a small piece of rubber that had fallen off the coil pack, it was stopping the current being passed from coil pack to plug thanks for the help.
  1. spark plugs
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2012, 16:54
  2. Help please : Can't get spark plugs out
    By Envy in forum Engine & Drivetrain
    Last Post: 25th July 2012, 21:56
  3. spark plugs
    By stuwtheleveller in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2011, 23:03
  4. Best oil and spark plugs
    By Sri-chris in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2011, 02:36
  5. 3.2 V6 spark plugs
    By Padster72 in forum Petrol Engine related
    Last Post: 10th May 2007, 17:30
